It is a device that controls the DC motor with a gear, which drives a three-way valve mixing water for underfloor heating so hot water does not flow to pipes.
Just provide TTL compatible signals:
- Dir – responsible for the direction of rotation
- Brake – responsible for brake
- PWM – responsible for speed
Additionally, there is a PWM generator of own production on the plate. When there is no need to change speed while working, it can be set once and adjustable only by direction and the drive on/off.
Signal source on the PCB can be switched by a jumper.
The whole project was described in science portal – link:
URL Laboratorium badawczo - rozwojowe PROTON
Below there is a video:
Link to original thread – LMD18200 - adapter sterujący silnikami DC
