+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Full Member level 3
    Points: 1,868, Level: 10
    Join Date
    Sep 2011
    Posts
    161
    Points
    1,868
    Level
    10
    speed control of single phase induction motor with TRIAC
    i want to use a 1µF capacitor to start the motor with a TRIAC to control the speed. Does anyone have the TRIAC circuit
    •   Alt17th October 2011, 08:11
      advertising
  2. #2
    Advanced Member level 3
    Points: 7,708, Level: 20
    Raza's Avatar
    Join Date
    Feb 2002
    PAK
    Posts
    829
    Points
    7,708
    Level
    20
    Re: speed control of single phase induction motor with TRIAC
    and
    Do you want two separate circuits for starting and speed controlling?
    This article gives a few circuits with application notes.
    http://www.st.com/internet/com/TECHN...CD00003856.pdf
    And here is project with PCB layout, too.
    Downloads / Electronic Circuits / AC Motor Speed Control using Triac : 8051 Microcontroller Projects AVR PIC Projects Tutorials Ebooks Libraries codes
    1 members found this post helpful.
    •   Alt17th October 2011, 11:55
      advertising
  3. #3
    Full Member level 3
    Join Date
    Sep 2011
    Posts
    161
    Points
    1,868
    Level
    10
    ya... two separating circuit. is it possible ?
    •   Alt19th October 2011, 12:57
      advertising
  4. #4
    Raza's Avatar
    Join Date
    Feb 2002
    PAK
    Posts
    829
    Points
    7,708
    Level
    20
    Look starting of motor has nothing to do with Speed control, as first motor has to start and go running then it will be possible to control speed. Here is a circuit to give you bit clarification of this:
    Click image for larger version.
    And if you want circuit notes, visit:
    AC Motor Speed Controller
    Any further help, if needed, is welcomed.
  5. #5
    Full Member level 3
    Join Date
    Sep 2011
    Posts
    161
    Points
    1,868
    Level
    10
    oh... ok, is this can work on single phase ?
