+ Post New Thread
Results 1 to 20 of 20
  1. #1
    Junior Member level 3
    Points: 590, Level: 5
    Join Date
    Sep 2011
    india, punjab
    Posts
    30
    Points
    590
    Level
    please again again help for turn ON and OFF a relay
    hi
    i want to turn on and off a relay using RF signal or using infrared remot control ,above the range 20-30-? meter,, for explain - i saw a L.E.D bulb wich ON and OFF with any cd,musicplayer and tv's remote set ,i am beginer so i want simple circuits , i want both RF and infrared
  2. #2
    Advanced Member level 3
    Points: 5,999, Level: 18
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
    Re: please help for turn ON and OFF a relay
  3. #3
    Points: 7,708, Level: 20
    Raza's Avatar
    Join Date
    Feb 2002
    PAK
    Posts
    829
    Points
    7,708
    Level
    20
    Visit the following links.
    3-Channel IR Relay Controller
    Infra Red Switch
    1 members found this post helpful.
    •   Alt1st October 2011, 18:11
      advertising
  4. #4
    Junior Member level 1
    Points: 1,778, Level: 9
    Join Date
    Dec 2005
    Posts
    19
    Points
    1,778
    Level
    9
  5. #5
    Join Date
    Sep 2011
    india, punjab
    Posts
    30
    Points
    590
    Level
    NO bro , this are not which i want, for explain - i saw a L.E.D bulb wich ON and OFF with any cd,musicplayer and tv's remote set , so pls give those simple circuit
  6. #6
    Raza's Avatar
    Join Date
    Feb 2002
    PAK
    Posts
    829
    Points
    7,708
    Level
    20
    Hi gurjeet,
    As I understood from your post, you need the response from the LED as it is in TV while controlling the Channel or Voice or in the face of CD player as it accesses the CD. It has a complicated circuitry and can not be achieved by a simple circuit.
  7. #7
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
  8. #8
    Full Member level 5
    Points: 2,589, Level: 11
    Join Date
    Nov 2009
    Kolkata, India
    Posts
    263
    Points
    2,589
    Level
    11
    Dear gurjeet
    first read RC5 Code
    this will tell you how remote controls are working after that using infrared you can control devices.
  9. #9
    Join Date
    Sep 2011
    india, punjab
    Posts
    30
    Points
    590
    Level
    my all dear frends i just want to turn on and off a relay using a tv remote's any IR signal, m not want any standard of it
    •   Alt5th October 2011, 15:24
      advertising
  10. #10
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
    Quote Originally Posted by gurjeet_saini View Post
    You need to know the standards. The tv remote is using that standard of IR signal. If you dont know, how would you receive them? Both transmitter and receiver needs to match!
  11. #11
    Join Date
    Sep 2011
    india, punjab
    Posts
    30
    Points
    590
    Level
    bro i think you are wrong, i see a L.E.D bulb wich on & off with any TV/CD 's remote by presing any key on remote
  12. #12
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
    It depends on what you want. If you want to press any button on the remote, and the blub light. That doesnt need any protocol. Just detect the IR light. But, If you need different button controlling different BULB. thats another different story.
    This might be what you want:
    http://pcbheaven.com/circuitpages/im...1292248033.png
  13. #13
    Super Moderator
    Points: 46,805, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,670
    Points
    46,805
    Level
    52
    Since you are talking about on/off operation, then is the relay inserted in the power line to the appliance? The relay is hooked up to a photodetector module that responds to 40kHz LED pulses alone? And doesn't care about the coded pulses?
    This will only work with units that power up when you connect power. Many units don't do that nowadays.
  14. #14
    Raza's Avatar
    Join Date
    Feb 2002
    PAK
    Posts
    829
    Points
    7,708
    Level
    20
    It seems very simple to see a LED blinking when any key is pressed on TV REMOTE control but it has a complicated circuitry inside to get it working. Almost a Microcontroller is inside REMOTE CONTROLLER and same on the other side inside TV.
    You can see just a Block Diagram pasted by BradtheRad and the actual circuitry will be much much more.
  15. #15
    Join Date
    Sep 2011
    india, punjab
    Posts
    30
    Points
    590
    Level
    BRADTHEred bro you are righit pls give me its schematic
  16. #16
    Super Moderator
    Join Date
    Apr 2011
    Posts
    11,670
    Points
    46,805
    Level
    52
    These are typical projects for homemade infra-red remote control:
    Infa-Red Remote Control
    Build a simple toggle ir remote receiver switch relay .....
    Use your TV Remote To Turn On Your Computer « Starlino Electronics
    Sci.electronics FAQ
    http://www.discovercircuits.com/PDF-FILES/40krvr1.pdf
    If you want to make your own sender unit, you must make it compatible with your photodetector module. It may not work for you to simply hook up an LED, push button switch, battery, and current limiting resistor (if needed). It's very common for IR remote control to operate on 38-40 kHz pulses.
    If you want the LED to send visible color, you'll get the best results by using the brightest type you can find, with a narrow beam, not a wide beam.
    •   Alt9th October 2011, 06:40
      advertising
  17. #17
    Full Member level 1
    Points: 1,665, Level: 9
    Achievements:
    7 years registered
    Join Date
    Jan 2011
    INDIA
    Posts
    104
    Points
    1,665
    Level
    9
    sonds like that your are want ir remote chacker.
    SANDEEP ANAND
  18. #18
    Join Date
    Sep 2011
    india, punjab
    Posts
    30
    Points
    590
    Level
    Quote Originally Posted by SANDEEP ANAND View Post
    no bro i want to turn on off a switch/relay
  19. #19
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Jan 2011
    INDIA
    Posts
    104
    Points
    1,665
    Level
    9
    sorry for misunderstanding your problem, i think i have exact circuit for you.wait till tomorrow i will get from my old collection.
    regards
    ---------- Post added at 19:58 ---------- Previous post was at 19:56 ----------
    regards
    SANDEEP ANAND
  20. #20
    Join Date
    Sep 2011
    india, punjab
    Posts
    30
    Points
    590
    Level
    regards
    regards
    ok bro pls give the circuit when u free
