+ Post New Thread
Results 1 to 20 of 20
  1. #1
    Full Member level 6
    Points: 2,765, Level: 12
    moonnightingale's Avatar
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    How to convert Square Wave to Sinewave
    I am getting square wave from 555 timer IC
    I want to convert it into sine wave and then feed it into speaker
    Kindly tell me how to convert Square wave to sine wave
  2. #2
    Full Member level 4
    Points: 2,256, Level: 11
    Join Date
    May 2011
    Posts
    192
    Points
    2,256
    Level
    11
    Re: How to convert Square Wave to Sinewave
    If you need a low cost solution, you could use a high order active analog filter (LOW PASS) after the 555. What you will obtain is not a perfect sinewave but it might work depending on your application.
    Another option would be making an analog sinewave generator like this one: A Sine Wave Generator
    Good luck!
    1 members found this post helpful.
  3. #3
    Full Member level 6
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    Basically i am having square wave of 400 Hz
    I want to convert it into Sinewave and listen on speaker,
    Kindly tell me which approach is good and easy to patch on breadboard
    •   Alt27th September 2011, 19:10
      advertising
  4. #4
    Advanced Member level 5
    Points: 39,631, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    The fundamental component of your square wave is the wanted sinusoidal signal.
    Therefore - as proposed above - use a lowpass and supress all higher harmonics as much as needed.
    The low pass order is determined by the accuracy you want to obtain (measured as THD).
  5. #5
    Full Member level 6
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    Ok thanks
    Can u give me link of some site which can show me circuit for low pass infreq range 300 Hz to 600 Hz
  6. #6
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    Texas Instruments Filter Pro is one of many available tools supporting the design of active filters. Active Filter Design Application - FILTERPRO - TI Software Folder
  7. #7
    Newbie level 3
    Points: 366, Level: 4
    Join Date
    Jan 2011
    Shenzhen, China
    Posts
    Points
    366
    Level
    For deriving sinusoid wave ,you'd better pick the filter type as Cauer (also be called as Elliptic) to reduce the order of the filter.
  8. #8
    Member level 3
    Points: 1,397, Level: 8
    mehtadhaval's Avatar
    Join Date
    Sep 2010
    Posts
    56
    Points
    1,397
    Level
    8
    If you just want to listen the 400Hz tone on the speaker then you can directly give 400Hz square wave directly to the speaker.
    Learning is a continuous process.....
    Dhaval Mehta
  9. #9
    Full Member level 6
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    yes i know i am also listening it on my speakers but i want to convert it into sine wave
    Somebody wrote that a simple RC circuit can convert square to sine wave
    How to calculate values of Resistor and Capacitor for 300 Hz Square Wave
    Kindly explain me their connectivity
    •   Alt28th September 2011, 13:36
      advertising
  10. #10
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Quote Originally Posted by moonnightingale View Post
    That`s nonsense. A simple RC circuit (first order lowpass) cannot change a squarewave into a sinusoidal signal. In theory, you would need an IDEAL lowpass (brickwall response) to remove all harmonics. As I told you earlier, a lowpass of order n=2...4 will do the job - depending on your THD requirements.
    Regarding Narshben`s suggestion, I doubt if an elliptical filter is the best choice for this purpose due to its complexity.
  11. #11
    Full Member level 6
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    Quote Originally Posted by LvW View Post
    Can u send me circuit diagram for any filter
    Thanks
  12. #12
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Thanks
    For "any filter"? Do you know that there are several books dealing only with filter design?
    And - what about Internet search?
  13. #13
    Full Member level 1
    Points: 1,155, Level: 7
    Join Date
    Jun 2011
    Bath, Somerset
    Posts
    115
    Points
    1,155
    Level
    7
    From what I remember, there is a triangular wave available at the timing inputs of a 555.
    Buffering this with an op-amp or Emitter follower stage and then using a 'triangle to sine' convertor comprising a series of back to back diodes with series resistors in the negative feedback path to shape the gain within an inverting op-amp stage can give a good approximation of a sinewave with distortion below 1%.
    I did use this method some years ago for an 'internal' reference signal, to avoid amplitude bounce as with Wein Bridge oscillators, within an Audio Mixing Desk but unfortunately no longer have the circuit info.
    Think this will be simpler than trying to use filtering of a squarewave to output a sinewave from your circuit....... although a simple lo-pass passive filter following the 'triangle to sine' convertor will further improve the residual sinewave distortion giving you a purer tone for listening tests with the 'speakers which you want to achieve.
    Seem to remember that there is some good info on this approach in the Analog Devices Application Notes, but can't remember which one(s) - hopefully someone else can remember where this info is?
    Hope this assists
    Mik
  14. #14
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    A 400 Hz low-pass. The yellow magnitude response is valid for the given component values.
  15. #15
    Full Member level 6
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    Quote Originally Posted by FvM View Post
    Actaully i am having several frequencies which are controlled through push button
    the range of my frequencies is from 250 Hz to 600 Hz
    will this filter work for whole range of frequencies
    I just tried this circuit which i got from internet. I changed the values of Inductor and capacitor by hit and trial and now i am getting perfect sinewave for almost whole range
    can u kindly explain me this circuitry. how it is producing the sinewave
    Pics are attached
  16. #16
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    That's difficult, because 3rd harmonic of 250 Hz is very near to 600 Hz. You didn't yet mention this requirement, by the way. But I assume, that you're able to find suitable filters from literature. The TI FilterPro software is one of many available resources.
    To generate a sine signal over a certain frequency range, a RC generator tuned with two resistors, e.g. a stereo potentiometer, seems more reasonable in my view. There are many previous threads about sine generators at Edaboard.
  17. #17
    Full Member level 6
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    ok thanks FVM
    Kindly comment about the circuit which i have uploaded
    How it is giving so good response
    Can u explain it
    thanks
  18. #18
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    WIth unloaded output (is it?), it's far from a regular low pass filter, e.g. having 10 dB peaking at 500 Hz. This suggests, that the filter requirements aren't actually very critical.
  19. #19
    Full Member level 6
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    ok thanks
    can u kindly explain me function of inductor and capacitor in this circuit
    •   Alt28th September 2011, 20:57
      advertising
  20. #20
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    The filter is a passive 3rd order low-pass, the corresponding LC implementation of the OP filter I posted above. My adjusting the L and C values, you can give it different filter characteristics.
    Some basics about passive filters can be found here: Lessons In Electric Circuits -- Volume II (AC) - Table of Contents
