"Frequency Bridge" for data translation
zorax85
Junior Member level 3
I'm working with two devices. One of them works at 50 MHz and the latter at 100MHz. Substancially from one side I should take data at 100MHz and translate them to 50MHz, and do the opposite on the other side. I should implement this bridge inside a CPLD, do you see any problem? Suggestions about how to make it working?
use a dual clocked FIFO. that would probably be the easiest approach.
Probably I'll follow that way, I have just used this approach last week in order to solve a similar problem. Thanks!
Other suggestions?
---------- Post added at 12:39 ---------- Previous post was at 11:41 ----------
Sorry, but as I told you before I'm using a CPLD, so it can not be possibile to use a core for a FIFO, that's why I was changing my approach instead of use the same of I already used (inside a FPGA).
XD
the solution depends of specification,
[data are transferred randomly, as a bunch, size of bunch, can a sender
wait until receiver is ready etc.]
you can implement a simple handshake protocol
'sink50_ready_for_data, source100_data_valid, sink50_data_accepted',
'sink100_ready_for_data, source50_data_valid, sink100_data_accepted';
or you can emulate a simplified fifo with cpld registers;
