+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 3
    Points: 1,605, Level: 9
    Join Date
    Aug 2004
    Posts
    27
    Points
    1,605
    Level
    9
    In IO pad, why do we need a floating Well?
    A lot of IO design use floating Nwell on the PMOS output transistors. For input IO cell, I guess this is to do with 5V tolerance. But why do we need a floating Nwell in output cells.
    Any one got a clear picture on this issue?
    •   Alt13th August 2004, 10:53
      advertising
  2. #2
    Full Member level 6
    Points: 5,505, Level: 17
    Join Date
    Aug 2004
    Scotland
    Posts
    395
    Points
    5,505
    Level
    17
    Re: In IO pad, why do we need a floating Well?
    For 3.3Volt logic IO,s that need to be 5Volt tolerant, a way of ensuring that the PMOS gate oxide never sees 5.5Volts across it is to use floating wells.
    •   Alt15th August 2004, 16:47
      advertising
  3. #3
    Advanced Member level 3
    Points: 7,066, Level: 20
    Join Date
    May 2004
    Posts
    874
    Points
    7,066
    Level
    20
    •   Alt16th August 2004, 04:30
      advertising
  4. #4
    Full Member level 1
    Points: 2,536, Level: 11
    Join Date
    Jun 2001
    Posts
    107
    Points
    2,536
    Level
    11
    For protecting the bonding wire connected with sub when bonding
