AC constant current source with constant frequency
catsilly
Newbie level 3
Hi, Can anyone give me a circuit for a AC constant current source with a constant frequency as well? I need a 2mA pk to pk while the frequency is set at 1KHZ. Thanks in advance
AC constant current source schematics.
Thanks! May I ask what op-amp you used?
Vcc=16v
Vce=-16v
0 < Load < 12K (Capacitive, resistive or inductive)
LM358 may be.
ac current from function generator
hi, I'm using a function generator to generate sine waves. However, I need the output of the function generator is in terms of volts. I need a way to convert the voltage into a constant current. Does anyone have any idea on how to accomplish this?
Don't start new threads with the same content. Threads merged [alexan_e]
