+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Advanced Member level 5
    Points: 33,086, Level: 44
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,646
    Points
    33,086
    Level
    44
    broadband patch antenna at 5.7 GHz?
    trying to make a broadband patch antenna 5.6 to 5.9 Ghz, probably on 62 mil thick FR4 board. I am close, but just can not get the final dimensions to give good VSWR across the whole band. Only getting maybe 6 dB return loss over the band on an E-shaped patch. It is really touchy, and each analysis pass takes a while...I may never converge on the final correct dimensions. (yes, I know it would be easier on a thicker substrate, or lower dielectric constant--like air, but I need it to be "cheap" and very manufacturable for a commercial job)
    Anybody have dimensons on such a beast?
    •   Alt19th September 2011, 12:24
      advertising
  2. #2
    Points: 16,136, Level: 30
    Join Date
    May 2010
    Santa Barbara
    Posts
    2,832
    Points
    16,136
    Level
    30
    Re: broadband patch antenna at 5.7 GHz?
    Any usual patch antenna exhibits resonant behaviour, so it cannot be used (and is not matched) over a wider band. I would try to use a bow-tie shaped antenna on a dielectric support. Or, for very wide bandwidth, there are some UWB antenna designs.
    I do not work in that area but Microwave Journal and Microwaves & RF magazines brought interesting antenna designs over last 3-5 years.
    •   Alt19th September 2011, 21:31
      advertising
  3. #3
    Points: 10,476, Level: 24
    Achievements:
    7 years registered
    tony_lth's Avatar
    Join Date
    Jul 2010
    Beijing
    Posts
    1,927
    Points
    10,476
    Level
    24
    Maybe you need more elements. I saw one my colleague designed such antenna with 1024 elements, and got about 20dB return loss.
    •   Alt19th September 2011, 22:03
      advertising
  4. #4
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,646
    Points
    33,086
    Level
    44
    the E shaped patch has 2 resonant frequencies, so you can make a double tuned vswr response.
  5. #5
    Points: 32,294, Level: 43
    Join Date
    Oct 2001
    Posts
    4,623
    Points
    32,294
    Level
    43
    Just another idea. U-shape slot antenna can get wide bandwidth.
    http://www.accessengineeringlibrary....6855_ar016.pdf
    1 members found this post helpful.
