+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Newbie level 5
    Points: 291, Level: 3
    Join Date
    Aug 2011
    Posts
    10
    Points
    291
    Level
    Re: delay code in vhdl
    Hi, I have an LED connected to CPLD I/O port i wrote the vhdl code to toggle the LED, but it is not visible. can anyone help me how to write a delay in vhdl with an example so that LED blinking is visible outside. do i need to use any looping technique. please help me:sad. Advance thanks.
    I wrote the program like (only architecture part)
    architecture Behavioral of toggle is
    begin
    c<=not c after 3000ms;
    end Behavioral;
  2. #2
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    Delay statements are simulation tools and don't work for hardware synthesis. You should consult your VHDL text book about the point. You'll need a clock connected to the CPLD, e.g. a crystal oscillator. You can divide it down to any low frequency you need.
    1 members found this post helpful.
    •   Alt14th September 2011, 15:16
      advertising
  3. #3
    Newbie level 5
    Join Date
    Aug 2011
    Posts
    10
    Points
    291
    Level
    oh okay... can we do it using counter in the programming.???
  4. #4
    Full Member level 5
    Points: 2,811, Level: 12
    Join Date
    Jan 2007
    Hyderabad
    Posts
    316
    Points
    2,811
    Level
    12
    Yes Please use counter based on the delay requirement.It will work
  5. #5
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    That's another word for dividing frequencies in my view.
    •   Alt15th September 2011, 06:44
      advertising
  6. #6
    Full Member level 5
    Join Date
    Jan 2007
    Hyderabad
    Posts
    316
    Points
    2,811
    Level
    12
    Quote Originally Posted by FvM View Post
    Yes it is........................
  7. #7
    Newbie level 5
    Join Date
    Aug 2011
    Posts
    10
    Points
    291
    Level
    thank you sivamani and FvM... I wrote the code like (only architecture part)
    architecture Behavioral of ctr is
    begin
    process(clk)
    variable cnt:integer:=0;
    begin
    loop
    --wait until clk='1';
    cnt:=(cnt+1) mod 65535;
    if(cnt=65535)then
    c<=cnt;
    end if;
    end loop;
    end process;
    end Behavioral;
    It is showing the error like
    ERROR:Xst:1312 - Loop has iterated 64 times. Use "set -loop_iteration_limit XX" to iterate more.
    how to resolve this..
  8. #8
    Advanced Member level 5
    Points: 35,434, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,434
    Level
    45
    your process is unclocked. you must clock the processs
  9. #9
    Full Member level 5
    Join Date
    Jan 2007
    Hyderabad
    Posts
    316
    Points
    2,811
    Level
    12
    Quote Originally Posted by karthiks30 View Post
    begin
    process(clk)
    begin
    loop
    if(cnt=65535)then
    c<=cnt;
    end if;
    end loop;
    end process;
    end Behavioral;
    Why cant you write code in this way?
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_unsigned.all;
    entity LED is
    port
    D : out std_logic_vector (3 downto 0);
    clk_50MHz : in std_logic;
    reset_n : in std_logic
    end entity;
    Architecture behaveior of LED is
    signal count :std_logic_vector(19 downto 0);
    signal Data :std_logic_vector (3 downto 0);
    Signal rst_low :std_logic <= "0";
    begin
    Process(clk_50MHz)
    if rising_edge(clk_50MHz) then
    if (reset_n = rst_low) then
    count <= (others => '0');
    data <= "0000";
    else
    count <= count + '1';
    if(count = 0) then
    data <= data(0) & data(3 downto 1);
    end if;
    end if;
    end if;
    end Process;
    D <= data;
    end behaveior;
    ---------- Post added at 05:31 ---------- Previous post was at 05:30 ----------
    Quote Originally Posted by sivamani View Post
    library ieee;
    entity LED is
    port
    end entity;
    begin
    Process(clk_50MHz)
    data <= "0000";
    else
    if(count = 0) then
    end if;
    end if;
    end if;
    end Process;
    D <= data;
    end behaveior;
    this code for roling leds with around 300ms time
    •   Alt16th September 2011, 05:31
      advertising
  10. #10
    Newbie level 5
    Join Date
    Aug 2011
    Posts
    10
    Points
    291
    Level
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.STD_LOGIC_ARITH.ALL;
    use IEEE.STD_LOGIC_UNSIGNED.ALL;
    ---- Uncomment the following library declaration if instantiating
    ---- any Xilinx primitives in this code.
    --library UNISIM;
    --use UNISIM.VComponents.all;
    entity counter is
    port(C : in std_logic;
    Q : out std_logic:='1');
    end counter;
    architecture archi of counter is
    signal t: std_logic:='1';
    constant cnt_max :natural := 250000000;
    begin
    process (C)
    variable cnt : natural range 0 to cnt_max :=0;
    begin
    if (C'event and C='1') then
    cnt := cnt + 1;
    if(cnt=cnt_max)then
    t<= not t;
    cnt:=0;
    end if;
    end if;
    end process;
    Q<=t;
    end archi;
    I have a JTAG connected to cpld.. clk pin is connected to I/OGCK and Q is connected to blink the LED. But still the LED is not toggling.. Do I need to provide any external crystal oscillator to the GCK pins of the cpld?? please help me.. thank you in advance..
  11. #11
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    As discussed before in this thread.
  12. #12
    Newbie level 5
    Join Date
    Aug 2011
    Posts
    10
    Points
    291
    Level
    Thank you for helping me out guys.. it worked, I connected the external clock for clk.....
