+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 6
    Points: 2,765, Level: 12
    moonnightingale's Avatar
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    Can any body explain me parameters of LED in proteus
    Hi can anybody explain me about parameters of LED in proteus
    What is diff between analog and digital LED
    Is there any documentation for Proteus 7.6 or any book which is good for begineers of proteus
    Thanks
    •   Alt10th September 2011, 08:45
      advertising
  2. #2
    Administrator
    Points: 37,969, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,969
    Level
    47
    Blog Entries
    Re: Can any body explain me parameters of LED in proteus
    if you open proteus VSM help -> advanced topics -> how to make simulation run faster -> digital resistor and diode models and also the analogue and digital simulation within ProSPICE link contained in that page you will see that the digital simulation uses digital states and is simulated much faster.
    What specific parameters are you interested in, I assume you already know about the forward voltage drop and current of the led, are you asking about the breakdown voltage?
    "If the reverse voltage grows large enough to exceed the breakdown voltage, a large current flows and the LED may be damaged", it is like a zener, after the specified voltage it starts to conduct and the current increases.
    Alex
    Please don't make requests for help in private using PM. Create a thread in the forum so that other members can benefit from the posted answers.
    Consider reading this before posting : How To Ask Questions The Smart Way
    •   Alt10th September 2011, 09:00
      advertising
  3. #3
    Full Member level 6
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    Thanks a lot Alexen
    Can u recommend me some book or tutorial for understanding circuit designing in proteus as i m new in this software
    •   Alt10th September 2011, 09:31
      advertising
  4. #4
    Administrator
    Achievements:
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,969
    Level
    47
    Blog Entries
    I don't know any, basically I have learned to use the program using the manual but you can ask here, if I know the answer I will help
    ---------- Post added at 11:47 ---------- Previous post was at 11:41 ----------
    you can also join the proteus group Proteus Design Suite - Simulation & PCB Layout - Forum for Electronics
  5. #5
    Full Member level 6
    Join Date
    Sep 2009
    Posts
    362
    Points
    2,765
    Level
    12
    Do u have manual in PDF Format.can u send me as i dont have any manual of proteus
    •   Alt10th September 2011, 09:51
      advertising
  6. #6
    Administrator
    Achievements:
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,969
    Level
    47
    Blog Entries
    you will also find a few tutorials on the forum, for example http://www.edaboard.com/thread159814.html
    ---------- Post added at 11:59 ---------- Previous post was at 11:58 ----------
    The manual is available from the proteus help menu, I don't have a PDF
