+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Newbie level 6
    Points: 2,103, Level: 10
    Join Date
    May 2001
    Posts
    13
    Points
    2,103
    Level
    10
    Information about the Wiegand Protocol used in security systems
    Does anybody have any information on the Wiegand Protocol used in security systems? I have noticed that there are a few different implementations of the protocol but I can't find any information on the net.
    Is there a specification available, and where can I get hold of it?
    Can somebody please help?
    Thanx
    TheBoss :(
    •   Alt30th September 2002, 16:08
      advertising
  2. #2
    Newbie level 6
    Join Date
    May 2001
    Posts
    13
    Points
    2,103
    Level
    10
    wiegand protocol specification
    Come on guys 26-bit wiegand? 34-bit wiegand? Doesn't anybody know anything about these protocols?
    I really appreciate any help...
    TheBoss :?
  3. #3
    Full Member level 3
    Points: 2,810, Level: 12
    fireplus's Avatar
    Join Date
    Oct 2003
    Posts
    182
    Points
    2,810
    Level
    12
    weigand protocol
    hi,
    may this link help you
    http://www.circuitcellar.com/avr2004...16abstract.pdf
    bye
    Fire in the Wire
    •   Alt14th March 2006, 14:57
      advertising
  4. #4
    Junior Member level 3
    Points: 3,095, Level: 13
    blue_snake's Avatar
    Join Date
    Jul 2001
    Posts
    30
    Points
    3,095
    Level
    13
    wiegand 26 protocol
    it is a 3 wire (GND, DATA0, DATA1):
    0's are impulses on DATA0 line
    1's are impulses on DATA1 line
    data bits are prefixed and postfixed with parity
    length of data bits chunk can vary from 24-40 bits
    i have somewhere in the archive my very old
    asm implementation for atmel (51 core)
    if you are interested ...
    •   Alt15th March 2006, 18:18
      advertising
  5. #5
    Member level 4
    Points: 1,853, Level: 10
    Join Date
    Sep 2004
    Egypt
    Posts
    70
    Points
    1,853
    Level
    10
    wiegand protocol pdf
    It is a protocol that is used in "Access Control Systems" mostly the wireless ones, the Door reader reads induces electric field throug its Antenna when the card is in the coverage field, it returns back a certain number that is the card number.
    Card Numbers can be formatted in many formats like the Wiegand and 35 system
    The wiegand-26- as an example splits the 26 bits into two groups of 13 bits
    the first group is used as a group identifier that all users within a corporate share, the other is user specific
  6. #6
    Newbie level 1
    Points: 1,128, Level: 7
    Join Date
    Aug 2006
    Posts
    Points
    1,128
    Level
    7
    wiegand 34
    I'm trying to interface a wiegand reader with a microchip micocontroller,I was reading the posts but I still can't get it,in datao I get the '0' and data1 the '1',has anyone a timimg diagram to understand how to read it??
    thanks a lot
    Javier
  7. #7
    Full Member level 1
    Points: 2,886, Level: 12
    Join Date
    Aug 2002
    malaysia
    Posts
    111
    Points
    2,886
    Level
    12
    wiegand protocol
    Hi
    You no need to see the timing digrame, you can used the interrup base, if u using the PIC16f84 you can used the portb 4:7 as input and setting as interrup base port.
    good luck
  8. #8
    Member level 2
    Points: 2,145, Level: 10
    Join Date
    Nov 2005
    Posts
    50
    Points
    2,145
    Level
    10
    wiegand 26 bit protocol
    Here you will find a diagram about Wiegand protocol:
    http://www.ibtechnology.co.uk/PDF/magswipe_dec.PDF
    cristi
  9. #9
    Junior Member level 1
    Points: 2,134, Level: 10
    Join Date
    Feb 2003
    Posts
    18
    Points
    2,134
    Level
    10
    wiegand protokoll
  10. #10
    Newbie level 1
    Points: 799, Level: 6
    Join Date
    Jun 2008
    Posts
    Points
    799
    Level
    wiegand specification
    You have a lot of information in Wikipedia!! http://en.wikipedia.org/wiki/Wiegand_protocol - just check out the links.
    In my company we use several wiegand interfaced devices. We normaly just convert the protocol to RS-485 / or USB. You can easily find these converters out there. Check, for example, (http://www.etconcept.com/Wiegand.htm).
    Best Regards
    Fazenda
    •   Alt22nd June 2008, 16:18
      advertising
  11. #11
    Newbie level 1
    Points: 588, Level: 5
    Join Date
    Sep 2009
    hyderabad
    Posts
    Points
    588
    Level
    Re: Wiegand Protocol
    iam using weigand protocol for accessing Card readers,can anyone help what is the maximum lenght shuold i connect my controller away from reader.i have connected about 20m distance between controller and reader,and used switching supply for the supply.iam getting a wrong data when i show a configured data.plz help me guys.
