+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 6
    Points: 3,892, Level: 14
    Achievements:
    7 years registered
    Join Date
    Jan 2008
    Central Florida
    Posts
    390
    Points
    3,892
    Level
    14
    zener diode usage in a reference schematic circuit
    I have a circuit that is used for manipulating solenoids. Basically I need help understanding the portion of the circuit C11,D8 and R19.
    I also need help understanding C10, R14 and D7.
    Why is D7 being used in reverse bias? Does a zener diode that operates in forward bias have the same i-v characteristics of a regular diode?
    •   Alt8th September 2011, 04:57
      advertising
  2. #2
    Advanced Member level 3
    Points: 7,708, Level: 20
    Raza's Avatar
    Join Date
    Feb 2002
    PAK
    Posts
    829
    Points
    7,708
    Level
    20
    Re: zener diode usage in a reference schematic circuit
    These diodes you referred are not Zener Diodes. These are New Generation Power Diodes (Super Barrier Rectifier). They have an edge on Shottky Diodes in low voltage usage.
    Here your referred circuits working as snubber network. If you see the Solenoids are fed positive supply voltage directly and the controlling FETS are making ground circuit, so for bypassing any transient due to inductive load this circuit is used.
    If you want information on SBRs here is the link for a better understanding.
    http://digitalcommons.calpoly.edu/cg...20rectifier%22
    Hope it helps.
    •   Alt8th September 2011, 08:03
      advertising
  3. #3
    Super Moderator
    Points: 241,624, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,962
    Points
    241,624
    Level
    100
    To understand the basic circuit function, you can consider the parts simply as regular diodes. For a detail analysis, you would need to know the coil R and L numbers. In a short, the circuit is intended to absorb inductive overvoltages. A simple freewheeling diode is apparently not suffcient, most likely releasing the coil too slow.
