C code for converting decimal number into N base number
jaywee03
functions in c
d :) oes anyone have a code or can you recomend a site were i can find a code that converts a decimal number into its equivalent N base no.(using functions). thanx!!!! :eek:
Re: functions in c
Cant realy give a link for this paticular function.
but have you tried **broken link removed** have loads of stuff.
Re: functions in c
You have to write your own function. It is quite easy.
start with
int conv(int base, long num)
rem = num%base.
num = num-rem.
rem gives the last byte
num is divisible base.
Re: functions in c
int convert(int base,long num)
while(n)
B=num%base;
num=num/base;
c[n]=B;
n=n-1;
n is data length based on some base.
B is middle variable.
num is data.
note: output c is reverse order.
