+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 1
    Points: 2,509, Level: 11
    Achievements:
    7 years registered
    Fractional-N's Avatar
    Join Date
    Oct 2007
    Posts
    97
    Points
    2,509
    Level
    11
    Need some interesting usage of electronics in agriculture
    Does anyone knows some of the amazing applications of electronics in agriculture?
    I'll be grateful if anyone could help me find some. Of course I need some technical (or detailed) information about those applications.
    thanks guys.
    •   Alt4th September 2011, 13:40
      advertising
  2. #2
    Full Member level 5
    Points: 1,583, Level: 9
    Join Date
    May 2011
    Posts
    246
    Points
    1,583
    Level
    9
    Re: Need some interesting usage of electronics in agriculture
    Start from designing humidity meter because the most important thing in agriculture is humidity . You need to make the meter for check the moisture in land.
    •   Alt4th September 2011, 16:04
      advertising
  3. #3
    Points: 9,709, Level: 23
    ALERTLINKS's Avatar
    Join Date
    Dec 2003
    Pakistan
    Posts
    1,259
    Points
    9,709
    Level
    23
    Then there is temerature meter and loggers.See also laser leveling techniche
    http://repairfaq.ece.drexel.edu/sam/MEOS/EXP22.pdf
    http://www.rwc.cgiar.org/pubs/167/Laser.pdf
    http://www.knowledgebank.irri.org/er...ing_manual.pdf
    ---------- Post added at 16:34 ---------- Previous post was at 16:20 ----------
    Soil moisture
    http://www.elp.uji.es/paperspdf/2002%20APL80-2785.pdf
    Make it youself
    The Cheap Vegetable Gardener
    ---------- Post added at 16:35 ---------- Previous post was at 16:34 ----------
    Plant + Insect Sciences
    •   Alt4th September 2011, 16:35
      advertising
  4. #4
    Full Member level 5
    Points: 3,007, Level: 12
    Achievements:
    7 years registered
    Join Date
    Feb 2008
    Turkiye
    Posts
    253
    Points
    3,007
    Level
    12
    incubation machine
    not much information on it but needs temp and humidity control i think.
  5. #5
    ALERTLINKS's Avatar
    Join Date
    Dec 2003
    Pakistan
    Posts
    1,259
    Points
    9,709
    Level
    23
  6. #6
    Advanced Member level 3
    Points: 4,522, Level: 15
    Join Date
    Jun 2010
    Posts
    724
    Points
    4,522
    Level
    15
    Auto-steering for tractors and chemical applicators. These are basically GPS guidance systems linked to a programmable auto-steer. They save labor, are extremely accurate, and save chemicals because there is no overlapping of paths. Also, the farmers can manage their stocks while sitting in the tractor cab.
    John
    •   Alt4th September 2011, 18:34
      advertising
  7. #7
    Newbie level 3
    Points: 230, Level: 2
    Join Date
    Sep 2011
    Posts
    Points
    230
    Level
    There are lot of usage electronics for Agriculture. Although I've not much info. about all those. but if you really wanna some good when then try to visit at a good electronic accessories online shopping store, where you will found all interesting USA use electronics used for Agriculture.
  8. #8
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Oct 2007
    Posts
    97
    Points
    2,509
    Level
    11
    Thank you all, my friends and specially thank you "ALERTLINKS". your links and information was great. I think I got enough things to study and work on.
