+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Advanced Member level 3
    Points: 3,812, Level: 14
    Join Date
    Jun 2011
    Posts
    839
    Points
    3,812
    Level
    14
    Spacing of conductorS in primary of offline SMPS?
    Hello,
    I wish to use the following 400V TO92 BJT in start-up linear regulator circuit of offline SMPS with Vin=90-265VAC.
    http://www.fairchildsemi.com/ds/KS/KSP44.pdf
    However, the legs are just 1.27mm apart......and obviously the pads will have rest-rings, -this will mean that the collector and emitter copper will be separated by just 1.8mm......and surely that is below the required minimum spacing of 3mm required for between positive and negative of the rectified DC Bus?
    However, i am sure many offline smps use KSP44 in their designs...so how are they getting away with it?
    •   Alt23rd August 2011, 18:25
      advertising
  2. #2
    Junior Member level 1
    Points: 326, Level: 3
    Join Date
    Aug 2011
    Posts
    17
    Points
    326
    Level
    Re: Spacing of conductorS in primary of offline SMPS?
    This may answer your question:
    Lead Spacing in a TO220 Package
    Regards :)
    1 members found this post helpful.
    •   Alt23rd August 2011, 19:28
      advertising
  3. #3
    Super Moderator
    Points: 239,566, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,505
    Points
    239,566
    Level
    100
    For the PCB footprint, you are free to bend the TO-92 pins to achieve the spacing of your choice.
    At the case side, you have however 0.8 mm creepage distance between B and C terminal which will hardly comply with most of the existing standards, e.g. IEC 1010, even for the lowest pollution degree. Experience suggests however, that the case side is less susceptible to creepage and flashover than the PCB side.
    •   Alt23rd August 2011, 20:38
      advertising
  4. #4
    Member level 1
    Points: 2,104, Level: 10
    Achievements:
    7 years registered
    Join Date
    Sep 2007
    Egypt
    Posts
    36
    Points
    2,104
    Level
    10
    Dear all,
    This a good tool for gap max. voltage calculations based on IPC-2222A standard.
    Best regards.
  5. #5
    Join Date
    Jun 2011
    Posts
    839
    Points
    3,812
    Level
    14
    Hi.
    I cannot seem to open the RAR file, i was wondering if their is another file liek this but not in RAR format.
    -just to show PCB track spacings in the primary of an offline 230VAC smps
