+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 6
    Points: 483, Level: 4
    Join Date
    Aug 2010
    islamabad
    Posts
    14
    Points
    483
    Level
    Convert Eagle layout into PDF
    Is there any way to convert the PCB layout made in Cadsoft eagle into a PDF? Kindly help me out.
    Thanks in advance.
    •   Alt18th August 2011, 11:26
      advertising
  2. #2
    Advanced Member level 5
    Points: 33,613, Level: 44
    ckshivaram's Avatar
    Join Date
    Apr 2008
    villingen (Germany) / Bangalore
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    Re: Convert Eagle layout into PDF
    you can convert EPS to PDF using Corel Draw.... try it......
    " It is so simple to be happy,
    but it is so difficult to be simple"
  3. #3
    Newbie level 6
    Join Date
    Aug 2010
    islamabad
    Posts
    14
    Points
    483
    Level
    Isnt there some other method? Some ULP to get the job done easier?
    •   Alt18th August 2011, 11:55
      advertising
  4. #4
    Newbie level 2
    Points: 468, Level: 4
    Join Date
    Aug 2011
    Posts
    Points
    468
    Level
    Hi maniyuri.
    Maybe you need to have installed previously the PDFCreator.
    This software simulates a virtual printer, but it translates the print preview of your PCB in a PDF file.
    I don't know if Eagle has a function for to convert directly a PCB layout in a PDF file, but you can be sure than PDFCreator runs perfectly.
    I usually use the PDFCreator for to convert schematics, layouts and other kind files in PDF files, with no care to source program used.
  5. #5
    Advanced Member level 1
    Points: 5,934, Level: 18
    Join Date
    Mar 2002
    UK
    Posts
    487
    Points
    5,934
    Level
    18
    Adobe Acrobat professional - if you have it you will not ask such questions and you can create PDF virtually from any application.
  6. #6
    Advanced Member level 3
    Points: 4,522, Level: 15
    Join Date
    Jun 2010
    Posts
    724
    Points
    4,522
    Level
    15
    You can also export directly as png, then convert that to pdf with Photoshop or other programs. I have not tested how accurate that conversion is.
    John
    •   Alt18th August 2011, 12:02
      advertising
  7. #7
    Super Moderator
    Points: 49,672, Level: 54
    Achievements:
    7 years registered
    keith1200rs's Avatar
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    There are various pdf generator programs. I use win2pdf. Most have a demo version which will work but will add either an extra page with a copyright notice, or a header/footer.
    Keith.
    ---------- Post added at 16:59 ---------- Previous post was at 16:54 ----------
    There is also a pdf option built into Eagle. Go to "print" and instead of selecting the printer at the top, select "print to file(pdf)". Type pdf in the help for more information.
    Keith.
    I started life with nothing and I've still got most of it left. (Seasick Steve)
  8. #8
    Newbie level 6
    Join Date
    Aug 2010
    islamabad
    Posts
    14
    Points
    483
    Level
    Hi Keith,
    The last option worked. Thanks
