+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Member level 2
    Points: 426, Level: 4
    Join Date
    Jun 2011
    Posts
    42
    Points
    426
    Level
    How to import inductor or balun layout from HFSS to CADENCE VIRTUOSO
    hi all,
    Does any one know How to import inductor or balun layout from HFSS to CADENCE VIRTUOSO???????????
    is it directly possible???????????????
    •   Alt13th August 2011, 11:09
      advertising
  2. #2
    Member level 4
    Points: 718, Level: 5
    raksha singh's Avatar
    Join Date
    Feb 2011
    mumbai
    Posts
    69
    Points
    718
    Level
    Re: How to import inductor or balun layout from HFSS to CADENCE VIRTUOSO
    yes it is possible i guess you just import the file to cadence..automatically it will get converted...
  3. #3
    Advanced Member level 5
    Points: 25,979, Level: 39
    Join Date
    Nov 2001
    Earth
    Posts
    3,669
    Points
    25,979
    Level
    39
    Convert your design into GDS2 file and then import it in Cadence..
    •   Alt14th August 2011, 05:01
      advertising
  4. #4
    Full Member level 2
    Points: 2,417, Level: 11
    Achievements:
    7 years registered
    Join Date
    Feb 2008
    Colorado, USA
    Posts
    128
    Points
    2,417
    Level
    11
    I use Altium and therefor I am not all that familiar with Cadence. Do you know what files you are able to import into Cadence? if you know what files you are able to convert into Cadence I would be happy to convert your HFSS design into that file format (My mechanical engineers work with solid works and that seems to be able to convert any format to any other format). I can also convert your balun into a gerber format and send it back to you. Let me know if there is a way I can help or a file format you want it your balun in,
    B
  5. #5
    volker_muehlhaus
    Quote Originally Posted by b4bb4ge View Post
    For Cadence RFIC, the top 3 file formats are:
    1. GDSII
    2. GDSII
    3. GDSII
    ddis can use GDSII and should have no problem. Gerber is only used in PCB, and make things more complicated anyway because each layer is in a separate file.
  6. #6
    Member level 2
    Join Date
    Jun 2011
    Posts
    42
    Points
    426
    Level
    hi all,
    i made GDSII file in HFSS from export option & tried to import it in the cadence Virtuoso layout
    but while exporting from HFSS it asked me for a LAYERMAP file & i skipped that step....
    so in cadence while importing the GDSII file the layout is shown but the metal lines are not shown in cadence defined colors
    i think the problem lies in layer mapping file
    i dont know what is layer map file
    Does someone can give me a sample layermap file for 180nm tech ???????
  7. #7
    Member level 2
    Join Date
    Jun 2011
    Posts
    42
    Points
    426
    Level
    hi all,
    i am trying to export my design as GDSII file from HFSS. By default HFSS gives its own layer no. I want to edit the layer no. so that yhe design is properly imported into cadence.
    I want to know if it is really possible.
    I have given a snapshot below to better understand the problem.........
    Thanks in Advance........
    •   Alt8th September 2011, 06:44
      advertising
  8. #8
    volker_muehlhaus
    Quote Originally Posted by ddis View Post
    Importing and Exporting Files
    Layer Map Files
    1 members found this post helpful.
