+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 3
    Points: 2,554, Level: 11
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Posts
    167
    Points
    2,554
    Level
    11
    coaxial simulation and characteristic impedance calculation
    Hi, there
    I 'd like to find some reference on simulation of coaxial balun. can anyone give me some advice?
    also I am confused about the impedance calculation of coaxial of say a EZ90-25 series semi rigid cable. From the datasheet we can see that its impedance is 25 ohms with outer diameter of 90 mils and that of inner of 40 mils, also we can find the dielectric constant of PTFE is 2.01, I think I can calculate the impedance, which is 25 ohms, from these data using formula
    but what I get is something 35 or so, not even close to 25, So anything wrong with my calculation?
    Thanks
    Julian
    •   Alt10th August 2011, 18:42
      advertising
  2. #2
    Super Moderator
    Points: 241,298, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,879
    Points
    241,298
    Level
    100
    Re: coaxial simulation and characteristic impedance calculation
    Seems like you didn't read the cable specifiation thoroughly. 90 mils is actually the copper tube outer diameter, the inner diameter (= dielectric diameter) is 73 mils. Semi-Rigid Coaxial Cable
    2 members found this post helpful.
    •   Alt10th August 2011, 19:17
      advertising
  3. #3
    Full Member level 3
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Posts
    167
    Points
    2,554
    Level
    11
    Cheers, get the right value,
    Thank you FvM for pointing my fault.
    Regards
