+ Post New Thread
Results 1 to 19 of 19
  1. #1
    Junior Member level 3
    Points: 363, Level: 4
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    How to get a modified sqare wave with 555 timer?
    hi everyone
    i am building a simple DC-AC inverter for my school project, i am stucked at how to use a 555 timer to generate control signals to control two MOSFET, which will output ON/OFF/OFF to one MOSFET and OFF/OFF/ON to the other MOSFET, is there a simple logic circuit to do the job? ideas?
    thanks
  2. #2
    Advanced Member level 2
    Points: 6,774, Level: 19
    blooz's Avatar
    Join Date
    Dec 2010
    India
    Posts
    561
    Points
    6,774
    Level
    19
    Blog Entries
    Re: How to get a modified sqare wave with 555 timer?
    Quote Originally Posted by ful24 View Post
    hi everyone
    thanks
    Generate A Square Wave 1/3 Duty Cycle 1 - 0 - 0
    and it's 180 phase shifted version(not gate ) is 0 -1 -1 ..
    Astable Multivibrator could be used .
    "In the middle of difficulty lies opportunity." -Albert Einstein
    •   Alt9th August 2011, 06:28
      advertising
  3. #3
    Advanced Member level 5
    Points: 37,620, Level: 47
    mister_rf's Avatar
    Join Date
    Feb 2008
    Romania
    Posts
    1,874
    Points
    37,620
    Level
    47
    1 members found this post helpful.
  4. #4
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    thanks mister_rf, thats exactly what im after.
  5. #5
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    quick question, isnt the discharge supposed to connect between the resistor? ( left side fo the diagram). to make the 555 astable.
    thanks
  6. #6
    mister_rf's Avatar
    Join Date
    Feb 2008
    Romania
    Posts
    1,874
    Points
    37,620
    Level
    47
    Yes, usually it’s better to use a resistor in between the capacitor and the discharge pin, in order to limit the maximum current flow through the internal transistor, but here as the 555 circuit need to fire only short pulses using smaller capacitor values you can skip this resistor. :-D
    •   Alt28th August 2011, 23:31
      advertising
  7. #7
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    aah, thats why! thanks for the quick reply.
  8. #8
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    there is a problem when i breadboard this circuit. there is a delay between the output of the comparator and the flipflop, which results the output of the ANDs are NOT what it suppose to be. is there any way to combat this problem?
  9. #9
    mister_rf's Avatar
    Join Date
    Feb 2008
    Romania
    Posts
    1,874
    Points
    37,620
    Level
    47
    Can you give more details on the timing diagram? :-)
    •   Alt31st August 2011, 21:21
      advertising
  10. #10
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    yes, i didnt save the waveform from the scope, ill do it tomorrow, and it is the Vcomp and Q&notQ out of phase, result the first & second transistor have different waveform form the graph above. ill try to describ it here and ill get the scope waveform later. the actual waveform i got is:
    time 0 30 60 90 120 150 180 210 240 270 300 330 360
    1st transistor on on off off on on off off off off off off off
    2ns transistor off off off off off off off on on off off on on
    ill get it in graph soon.
  11. #11
    mister_rf's Avatar
    Join Date
    Feb 2008
    Romania
    Posts
    1,874
    Points
    37,620
    Level
    47
    Can you attach also the diagram with components types/value used for?
  12. #12
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    Click image for larger version.
ID:	61099Click image for larger version.
    the first graph is the output of transistor 1 and 2.
    the second graph is the inputs of the AND gate.
  13. #13
    mister_rf's Avatar
    Join Date
    Feb 2008
    Romania
    Posts
    1,874
    Points
    37,620
    Level
    47
    What about some graph for the ‘555’ output and Comparator output?
    What components are you using for? Any details?
  14. #14
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    ill upload the details asap. sorry about the inconvenience.
  15. #15
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    ok, i used 555timer; 4027(dual J-K flip-flop); LM339(Quad voltage comparator); 4081(Quad 2-input AND gate). circuit is same as the circuit above, resistors and capacitors are used to get a 50Hz and 50% duty cycle. and i didnt terminate any unused pins. i asked the tutor he said its the delay of the 555timer and flip-flop. that caused the phase shift between flip-flop output and comparator output.
  16. #16
    Super Moderator
    Points: 239,611, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,611
    Level
    100
    Doesn't sound reasonable. 4027 and 555 have delays in < 1us range, even the comparator response time is much faster than the delays viewn in your waveform. The circuit must be different from the above suggestion somehow. I would expect a small delay of the comparator output, it may be necessary to apply a correction (e.g. 555 discharge resistor) to avoid a very short pulse at the ramp start.
  17. #17
    mister_rf's Avatar
    Join Date
    Feb 2008
    Romania
    Posts
    1,874
    Points
    37,620
    Level
    47
    It’s very important to have all graphs placed on a new diagram before start to compare timings.
    •   Alt5th September 2011, 16:50
      advertising
  18. #18
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    thanks for the reply gusy, sorry about not posting enough information, i have been very busy attending lectures and breadboarding in the lab, havnt got much time to get on a computer. im going to re-connect the circuit and try different component values. i agree with FvM, ill try to post the circuit diagram asap. (can only view the diagram at school)
  19. #19
    Join Date
    Aug 2011
    Posts
    27
    Points
    363
    Level
    problem solved, the delay i had before was caused by the resistor i placed between "discharge" and "threshold". i re-do the whole circuit again without that resistor, and there is no deplay at all, or acceptable delay.
    anyway, thanks all for the information.
