lcd and switch multiplexing with 18f452 portb
zeroskj1988
Member level 2
i am using pic18f452.inmy project,i have to multiplex LCD(jhd539,16X4) and switches. i am using lcd in 4 bit mode
i directly connected switch and data line of lcd to portb<1-4>.when am working with pgm there is random variations.my doubt is whether there is any problem in multiplexing directly. pls help me
thanks in advance
It would be better to see the schematic.
It is not advisable to connect datalines and keypad to same port pins directly.
thanks in advance
You can easily connect the switches and LCD on the same lines. See the attached schematic. the pull up resistors are 4K7 and pull doen are 1K.
Cheers
Ravi
thank u sir
i using schematic similar to your,except the pull up resistor
but i am getting response that some keys pressed even if am not pressed it
