+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 1
    Points: 965, Level: 7
    Join Date
    Oct 2010
    Posts
    117
    Points
    965
    Level
    7
    Question about BJT in saturation
    i have some question about biasing the bjt into saturation, and its switch configuration
    1. Is it necessary to have Vce <= 0.2 in order for bjt to saturate?
    2. So what if a very low resistive load is connected to it, since I think usually it will then have Vce greater than 0.2, so that means bjt can never be saturated under low load condition?
    3. is the switch configuration is just common emitter?
    4. can I have the bjt as a switch in emitter follower?
    your help will be greatly appreciated!
    •   Alt5th August 2011, 12:41
      advertising
  2. #2
    Points: 17,009, Level: 31
    kak111's Avatar
    Join Date
    Mar 2011
    Finland
    Posts
    1,366
    Points
    17,009
    Level
    31
    Blog Entries
    8
    Re: Question about BJT in saturation
    Answer: 1&2
    Click image for larger version.
    Answer: 3&4
    We can say that BJT act as switch , if it works only in cutoff and saturation states.
    Transistor Switches
    ---> Hike with wise men , then you will be wise <---
    •   Alt5th August 2011, 13:58
      advertising
  3. #3
    Points: 783, Level: 6
    Join Date
    Sep 2008
    Posts
    Points
    783
    Level
    1. Not necessary
    2. saturation is the condition Ic< Beta *iB
    3. yes with Rc* Beta > Rb
    4 yes switch is on when base is tied to vcc ; off when base is tied to ground
    •   Alt5th August 2011, 14:03
      advertising
  4. #4
    Administrator
    Points: 37,969, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,969
    Level
    47
    Blog Entries
    Quote Originally Posted by hayowazzup View Post
    You don't set the Vce to saturate but you have a low Vce as a result of the saturation, the Vce level is not exact it can be higher too
    2. So what if a very low resistive load is connected to it, since I think usually it will then have Vce greater than 0.2, so that means bjt can never be saturated under low low condition?
    Again the low Vce is not a requirement for the transistor to saturate but the result of a saturated transistor, the Vce voltage can have a higher level too.
    You can either have the load connected to the collector or the emitter.
    When the load is connected to the collector then you can control a load that has a higher voltage then the base.
    When the output is the emitter then the output will always have a 0.7v difference from the base, so for example with a 5v to the base of a NPN you will only get 4.3v to the emitter ot with 0v to the base of a PNP you will get 0.7v to the emitter.
    Alex
    Please don't make requests for help in private using PM. Create a thread in the forum so that other members can benefit from the posted answers.
    Consider reading this before posting : How To Ask Questions The Smart Way
