+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 2
    Points: 1,923, Level: 10
    Join Date
    Apr 2005
    Posts
    47
    Points
    1,923
    Level
    10
    Altium Designer - Shorting to Internal Plane
    Hi All,
    I'm currently evaluating Altium 10 on a small project.
    I want to intentionally connect a one pin from a connector to an internal DGND plane (negative plane).
    However this pins is from a different net.
    I cant add the "short circuit" rule to this net since I only want it to short to DGND at one pin and not at all pins connected to this net.
    May I know how to do this?
    Alternately is there a way to convert the internal negative plane to a positive plane so I can just add a trace to short it?
    Thanks All,
    Newbie101
    •   Alt20th July 2011, 04:46
      advertising
  2. #2
    Member level 3
    Points: 1,520, Level: 8
    Join Date
    Jul 2006
    Nürnberg, Germany
    Posts
    64
    Points
    1,520
    Level
    8
    Re: Altium Designer - Shorting to Internal Plane
    Instead of using a plane you can use a normal layer with polygen pour connected to DGND
    1 members found this post helpful.
    •   Alt20th July 2011, 11:39
      advertising
  3. #3
    Member level 2
    Join Date
    Apr 2005
    Posts
    47
    Points
    1,923
    Level
    10
    Dear Khanna_Gunjan,
    Yes, that is one possible solution which I will use if no other method available.
    Does anyone know how to short pins on negative layers in Altium Designer?
    Thanks,
    Newbie101
    •   Alt20th July 2011, 11:50
      advertising
  4. #4
    Advanced Member level 5
    Points: 12,081, Level: 26
    Achievements:
    7 years registered
    Join Date
    Feb 2010
    UNITED KINGDOM
    Posts
    1,919
    Points
    12,081
    Level
    26
    Why use negative planes these days?
  5. #5
    Member level 2
    Join Date
    Apr 2005
    Posts
    47
    Points
    1,923
    Level
    10
    Quote Originally Posted by marce View Post
    Dear Marce,
    Well, it is the default setting for planes in Altium.
    (Note:- I'm not too familiar with using this software)
    Is there a way to set a plane layer in Altium to be positive?
    I could change the layer to a signal layer and place shapes, but I'm not sure if it the correct way to do this.
    Thanks,
    Newbie101
    •   Alt20th July 2011, 17:04
      advertising
  6. #6
    Advanced Member level 2
    Points: 5,187, Level: 17
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    India
    Posts
    507
    Points
    5,187
    Level
    17
    There is another method of doing this what you can do is you can manually change the net name of that particular pin from connector to DGND by going to pin's property.
    Remember that this done in PCB only so next time when you ECO update from your schematic it will be gone.
  7. #7
    Member level 2
    Join Date
    Apr 2005
    Posts
    47
    Points
    1,923
    Level
    10
    Thanks Ricky
    Your solution works perfectly!!
