+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 3
    Points: 1,090, Level: 7
    Join Date
    Jan 2011
    Khulna,Bangladesh
    Posts
    Points
    1,090
    Level
    7
    Clear Timer on Compare Match(CTC) Mode problem
    I have faced problems in working with CTC in atmega. I can not produce interrupt after 1 second using CTC. I observed that the value of OCR1AH is not compared with with TCNT1H .What can be done?
    Suggest needed.My code is following........
    #include <built_in.h>
    int a=0;
    void Timer1compa_ISR() org IVT_ADDR_TIMER1_COMPA
    PORTB=~PORTB;
    PORTD=0xFF;
    void main()
    int i;
    DDRB=0xFF;
    DDRD=0xFF;
    DDRC=0xFF;
    SREG_I_bit=1;
    TIMSK |= (1<<OCIE1A);
    TCNT1L=0;
    TCNT1H=0
    i=4870;
    OCR1AL=Lo(i);
    OCR1AH=Hi(i);
    TCCR1B |= (1<<WGM12);
    TCCR1B=0x0D; /*start timer with presscaler of clk/1024*/
    /*Timer/Counter1, Output Compare A Match Interrupt Enable*/
    while(1)
    PORTB=0x0F;
    •   Alt14th July 2011, 19:49
      advertising
  2. #2
    Administrator
    Points: 37,998, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,998
    Level
    47
    Blog Entries
    Re: Clear Timer on Compare Match(CTC) Mode problem
    You are missing
    // timer1 compare match A ISR on
    TIMSK=0x10;
    I also don't know why you use TCCR1B |= (1<<WGM12); when in the next line you write a new value TCCR1B=0x0D;
    Alex
    P.S. actually the TIMSK exists in your code.
    I an not familiar with your compiler but maybe the value is the problem, can you use OCR1A=i ?
    There should also be somewhere a global enable interrupt (for example it is sei() in avrgcc)
    Please don't make requests for help in private using PM. Create a thread in the forum so that other members can benefit from the posted answers.
    Consider reading this before posting : How To Ask Questions The Smart Way
    •   Alt14th July 2011, 21:43
      advertising
  3. #3
    Newbie level 3
    Join Date
    Jan 2011
    Khulna,Bangladesh
    Posts
    Points
    1,090
    Level
    7
    Here i have a problem like i am using mikroC as compiler , in it the following code is not accepted ....
    OCR1A=i;
    when i declare such as......
    OCR1AL=i;
    then it is accepted but it is only possible when ( i<255 )
    if i>255
    then i have to declare it like
    OCR1AL=Lo(i);
    OCR1AH=Hi(i);
    but in this case the OCR1AH value is not compared with the value of TCNT1H only the value of OCR1L value is compared as a result i could not able to compare a large time.
    I can not understand actually what i have to do. Help needed..
    •   Alt15th July 2011, 08:11
      advertising
  4. #4
    Newbie level 3
    Join Date
    Jan 2011
    Khulna,Bangladesh
    Posts
    Points
    1,090
    Level
    7
    CTC problem in atmega with mikroC compiler
    I need a normal code of Timer1 CTC for atmega in mikroC. I have made a simple code but i can not understand where is my error i can not compare time when i>255.
    Help needed.
    #include<built_in.h>
    unsigned int i;
    void inerrupt_ISP() org IVT_ADDR_TIMER1_COMPA
    PORTB = ~PORTB ;
    void square_wave_init(void)
    DDRB = 0xFF;
    TCNT1L=0;
    i=4870;
    OCR1AL = i;
    OCR1AH=Hi(i);
    TCCR1B |= (1<<CS10) | (1<<CS12);
    //TCCR1A=0b01010000;
    void main()
    square_wave_init();
    SREG_I_bit=1;
    while(1){ ;
