How to assign values for vpulse(library file in pspice)
aryasubhash92
Newbie level 3
I want to know how values are assigned to VPULSE in PSPICE for a sweep wave generator?
Moved to PCB Routing & Schematic Layout software & Simulation. Select the proper category for your posts [alexan_e]
May be this link will be helpful.
Thank You!
Here are the parameters:
Parameters Description Units Default
<v1> Initial voltage volts none
<v2> Pulsed voltage volts none
<td> Delay sec 0
<tf> Fall time sec TSTEP
<tr> Rise time sec TSTEP
<pw> Pulse width sec TSTOP
<per> Period sec TSTOP
Hope this helps.
