+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Junior Member level 1
    Points: 1,988, Level: 10
    Join Date
    Aug 2005
    Russia
    Posts
    15
    Points
    1,988
    Level
    10
    Identify green toroid cores in common-mode chokes?
    Hello,
    I've seen green toroid cores for common-mode chokes in few power supplies from different manufacturers. Can somebody please write the manufacturer?
    Regards
    •   Alt30th June 2011, 10:25
      advertising
  2. #2
    Join Date
    Aug 2005
    Russia
    Posts
    15
    Points
    1,988
    Level
    10
    Re: Identify green toroid cores in common-mode chokes?
    Has anybody here seen real power supply?
    •   Alt26th July 2011, 07:51
      advertising
  3. #3
    Join Date
    Aug 2005
    Russia
    Posts
    15
    Points
    1,988
    Level
    10
    Measured relative permeability (mu) is about 2700.
    •   Alt13th September 2011, 09:59
      advertising
  4. #4
    Advanced Member level 5
    Points: 35,381, Level: 45
    Join Date
    Mar 2008
    USA
    Posts
    5,677
    Points
    35,381
    Level
    45
    I don't have any specifics for you, but while you're waiting
    I recommend you try chasing through vendor web sites for
    switching power supplies, for app notes and reference
    designs on EMI/EMC. These may have BOMs or part detail
    for the input filter components and maybe that's the start
    of the trail.
    1 members found this post helpful.
  5. #5
    Join Date
    Aug 2005
    Russia
    Posts
    15
    Points
    1,988
    Level
    10
    Thank you, it's a good advice, however the trouble is that AN authors usually don't bother much about this, they buy some off-the-shelf choke and state the part number and the manufacturer. I'll keep trying.
    •   Alt15th September 2011, 05:04
      advertising
  6. #6
    Advanced Member level 3
    Points: 7,708, Level: 20
    Raza's Avatar
    Join Date
    Feb 2002
    PAK
    Posts
    829
    Points
    7,708
    Level
    20
    I have seen some other colors too like Yellow but there is no specific link between the color type of material. If you can extend your efforts a bit just measure a known material's permeability and then compare with this one for the same inductance. As I could conclude is that this paint is just to give an extra shortening feature to the wire used for winding.
    Could not fine any particular datasheet about the color identified cores.
  7. #7
    Points: 19,665, Level: 34
    Achievements:
    7 years registered
    Join Date
    Jan 2011
    Posts
    3,265
    Points
    19,665
    Level
    34
    I know at least micrometals use colors to identify the core material, with no other markings, but I don't believe they make any cores that are completely green. If the permeability is that high it must be a ferrite or tape wound core. I'd try looking at Arnold magnetics to see if they make anything like it in that color.
    But honestly if it's meant as a common more choke, then its exact properties probably aren't terribly important. You know the permeability and size, so that's a lot right there. Just find something similar. The only other thing you might want to look at is what frequency it works up to (if you have a network analyzer).
