+ Post New Thread
Results 1 to 15 of 15
  1. #1
    Points: 335, Level: 3
    Join Date
    Mar 2011
    Posts
    Points
    335
    Level
    16x2 lcd display problem
    my 16x2 lcd is working in a PIC development board with sample program of MikroC.
    but same connection, doesnt work in my circuit. i dont kno whats wrong.
    normally if power is supplied to LCD, dark square boxes will appear on screen. but in my case, i cant get that from my circuit. so, i took it as some kind of power problem. i get the power from a function generator. im using Variable resister for reference voltage pin.
    do you have any idea to solve the problem?
  2. #2
    Advanced Member level 5
    Points: 33,613, Level: 44
    ckshivaram's Avatar
    Join Date
    Apr 2008
    villingen (Germany) / Bangalore
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    Re: 16x2 lcd display problem
    post your circuit and code here...
    " It is so simple to be happy,
    but it is so difficult to be simple"
    1 members found this post helpful.
  3. #3
    Newbie level 6
    Points: 399, Level: 4
    Join Date
    Jun 2011
    Posts
    14
    Points
    399
    Level
    Hi
    Even I faced the same problem when interfacing LCD with some other microcontroller, Check the applied Vdd voltage to the LCD , check for proper grounding of LCD and have u placed a POT for the backlight adjustment if all these are proper then I think the problem might be with your code ie your code is being struck somewhere.
    AS
    •   Alt30th June 2011, 05:17
      advertising
  4. #4
    Newbie level 6
    Points: 364, Level: 4
    Join Date
    Jun 2011
    Posts
    14
    Points
    364
    Level
    firstly only connect
    pin 1-->GND
    pin 2-->VCC
    pin 3-->pot(10k) varying between vcc and gnd
    pin15-->GND
    pin16-->Vcc
    The backlight should glow and after adjusting the pot...you will get black rectangles on one line...lower line
  5. #5
    ckshivaram's Avatar
    Join Date
    Apr 2008
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    What is your voltage and current rating????/
    •   Alt30th June 2011, 06:19
      advertising
  6. #6
    Newbie level 6
    Join Date
    Jun 2011
    Posts
    14
    Points
    364
    Level
    Yes you should probably tell us what lcd you have...atleast the name on the lcd...so that we can refer to the datasheet
    •   Alt30th June 2011, 06:24
      advertising
  7. #7
    Join Date
    Mar 2011
    Posts
    Points
    335
    Level
    my LCD is LMB162ABC
    i think i have problem with reference voltage supply..
    i set that as 1V-2V by using resistor and variable resistor..
    and need to know the range of the reference voltage...
  8. #8
    ckshivaram's Avatar
    Join Date
    Apr 2008
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    You mean reference supply voltage at pin 3 of LCD. it i am right then it should be 5V and controlled via a potentiometer......
  9. #9
    Newbie level 6
    Join Date
    Jun 2011
    Posts
    14
    Points
    364
    Level
    yes you need to connect a potentiometer(10k would do) at pin 3,
    the input to that pin must vary from 0-Vcc...its the contrast adjustment
  10. #10
    Join Date
    Mar 2011
    Posts
    Points
    335
    Level
    what is the max voltage has to be given to pin-3 by potentiometer..?
    one of my mate says, the range for contrast adjustment is 0V - 0.7V... it means- 0V for high contrast, and 0.7V for minimum contrast. from the potentio meter we need to set that voltage to pin-3. is it correct? i ddint check it that.
    Can we Ground the 3rd pin?
  11. #11
    Newbie level 6
    Join Date
    Jun 2011
    Posts
    14
    Points
    364
    Level
    Niru just make a small connection...
    do not connect your microcontroller right now.
    just connect the power...
    pin 1-->gnd
    pin 2-->Vcc
    pin 3-->potentiometer(10k) middle pin(potentiometers other pins connected to vcc and gnd)
    pin15(anode)-->330 ohm resistance-->Vcc
    pin16(cathode)-->GND
    turn the potentiometer to see the effect
    Check the datasheet of your device you will find these settings i have given above...
  12. #12
    Full Member level 4
    Points: 2,538, Level: 11
    Achievements:
    7 years registered
    g_shyam1682's Avatar
    Join Date
    Jan 2010
    Udaipur-Rajshan-India
    Posts
    206
    Points
    2,538
    Level
    11
    Hi friend
    I have experiance that
    if data line is not connected properly then also this type of problem arise.
    Check your data line connection between micro and LCD
    Shyam,
  13. #13
    Join Date
    Mar 2011
    Posts
    Points
    335
    Level
    thanks all for the valuable advice..
    i have solved the problem..
    normally potentiometer is used to supply reference voltage to pin-3... so we can adjust the voltage value of pin-3 by potentiometer. the voltage range of pin-3 has become 0V-5V..
    before i thought we need to give high reference supply for high contrast..(for LMB162ABC). but for the high contrast, low voltage has to be given to pin-3. it should be 0V-0.7V.. ( 0V for max contrast, 0.7V for min Contrast).
    i have grounded the 3rd pin with out using any potentiometer, and got the wright ans..
    thank u all..
    •   Alt2nd July 2011, 02:16
      advertising
  14. #14
    Newbie level 1
    Points: 162, Level: 2
    Join Date
    Jan 2012
    Posts
    Points
    162
    Level
    i have the same problem.my code runs smoothly but when i tested it on real lcd, no display is shown. can you help tell me the what's the problem?
    2 members found this post helpful.
  15. #15
    Newbie level 5
    Points: 219, Level: 2
    Join Date
    Dec 2013
    Posts
    10
    Points
    219
    Level
    16*2 lcd
    pin 1 -->> ground
    pin 2-->> vcc
    pin 3 -->> 1k resistor between ground Click image for larger version.
