+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 5
    Points: 2,709, Level: 12
    Basil's Avatar
    Join Date
    Jan 2003
    Posts
    91
    Points
    2,709
    Level
    12
    surface mount diode markings
    I have a shortcircuited (it failed) surface mount component. I'm pretty sure it is a diode.
    Itīs associated to the power supply board area.
    The size of the package (plastic) is 4 x 3 mm (i.e. 160 x 120 mils). Cathode is marked with a line. I believe the package is SMB
    Marks:
    On the top left corner the word "ON" in a circle (this is a logo), to the rigth of this logo 249 and exactly below the "249" is B14
    non code from Onsemi aplies to this diode, but the logo sugest it could be Onsemi...
    Thank you for help me. Itīs saturday night and I'm in a hurry with this stuff.
    •   Alt25th July 2004, 01:32
      advertising
  2. #2
    Advanced Member level 5
    Points: 32,456, Level: 44
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    b14 diode
    249 sounds like a date code.
    I searched ON for "diode marking B14", and found the MBRS140 diode:
    http://www.onsemi.com/pub/Collateral/MBRS140T3-D.PDF
    Hope that helps!
    •   Alt25th July 2004, 07:00
      advertising
  3. #3
    Member level 5
    Basil's Avatar
    Join Date
    Jan 2003
    Posts
    91
    Points
    2,709
    Level
    12
    surface mount diode identification
    thanks Echo7! :D
    Nevertheless if you search b14 in the home page of ON Semiconductor you get zener diodes!!!. See yourself: http://www.onsemi.com/site/products/...archString=b14 in SMB packages too.
    Because it is a multilayer board itīs pretty difficult to draw the circuit.
    Edited on July, 30
    Epilog
    The diode was a B14.
    What a mess is to identify a surface mount component identification guys.
    •   Alt25th July 2004, 13:16
      advertising
  4. #4
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    Search engines!
    I entered "diode marking B14" into the "General" search field at http://www.onsemi.com/
    Hit #5 was the good one.
    Happy troubleshooting. :)
