+ Post New Thread
Results 1 to 2 of 2
12th June 2011, 23:17 #1
- Join Date
- Mar 2010
- Posts
- 18
- Helped
- 0 / 0
- Points
- 562
- Level
- 5
export gds using virtuoso
Hi all,
after doing the file-->export-->stream and insert the layout cellview (+library and tech_file), in the summary it says that each part in my design is translated to a STRUCTURE.
does that means that when i will do an importing of the stream, it wont recognize the Pcells??
(my objective is to send someone my gds + CDL (also stream-schematic) + tech_file (by dumping) that he will run LVS checks.. - need anything else??)
second, when i tried to check it by importing it, i got an error that the "Target library 'ADC_zvika' (my library) is attached to the technology library 'ts...'. therfore, technology file is opened in read-only mode.
12th June 2011, 23:27 #2
- Join Date
- Jul 2009
- Location
- USA
- Posts
- 425
- Helped
- 159 / 159
- Points
- 4,010
- Level
- 14
Re: export gds using virtuoso
streamout will by default suppress p-cells as those are usually cadence specific and GDS is not
There are options to keep them but that does not seem a good thing in your case
If you want someone to check your design for you
- CDL
- GDS
- LVS rule file specific to whatever tools he uses for verification
- make sure port stamping in GDS is compatible with that LVS tool
Never stream your GDS back into the original library because by default it will overwrite it!!
+ Post New Thread
Please login
