+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Full Member level 5
    Points: 3,726, Level: 14
    Achievements:
    7 years registered
    cool.man's Avatar
    Join Date
    May 2008
    Earth
    Posts
    314
    Points
    3,726
    Level
    14
    What voltage levels are required for transmitting data using modbus protocol?
    I am using modbus protocol with rs485.for rs485 i am using sn75176 IC.
    I want to know that what voltage levels are required for transmitting data over the wires.
    Also is there any version of sn75176 available which can run at 3.3v?
  2. #2
    Newbie level 6
    Points: 567, Level: 5
    Join Date
    Feb 2010
    pune
    Posts
    14
    Points
    567
    Level
    Re: Modbus voltage level
    its 5v Bro.
    •   Alt9th June 2011, 11:28
      advertising
  3. #3
    Advanced Member level 5
    Points: 33,613, Level: 44
    ckshivaram's Avatar
    Join Date
    Apr 2008
    villingen (Germany) / Bangalore
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    " It is so simple to be happy,
    but it is so difficult to be simple"
    •   Alt9th June 2011, 12:56
      advertising
  4. #4
    Full Member level 5
    Achievements:
    7 years registered
    cool.man's Avatar
    Join Date
    May 2008
    Earth
    Posts
    314
    Points
    3,726
    Level
    14
    Why this kind of circuit is needed after 75175 IC
    •   Alt11th June 2011, 07:49
      advertising
  5. #5
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    Re: What voltage levels are required for transmitting data using modbus protocol?
    You mean on the left side? A microprocessor, I guess. You'll need RX, TX and TX_Enable signals.
    Referring to your original question, yes you can interface RS-485 with a 3.3V supplied driver. These drivers have the same pinout as 75176 and are available e.g. from TI. The voltage levels are specified by the RS-485 standard, there are no particular requirements for MODBUS.
  6. #6
    Full Member level 5
    Achievements:
    7 years registered
    cool.man's Avatar
    Join Date
    May 2008
    Earth
    Posts
    314
    Points
    3,726
    Level
    14
    FvM,
    what i wanna ask is that in the attached picture a resistor network is connected to pin 6 and 7.
    I wanna know why this configuration is done if we can run modbus at 5v or 3.3v
    What are the advantages of this kind of circuit?
  7. #7
    Administrator
    Points: 69,113, Level: 64
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,113
    Level
    64
    Blog Entries
    The Modbus specification only covers the implementation of a Application Layer (Layer 7 OSI Model) and a Datalink Layer (Layer 2 OSI Model), the actual Physical Layer (Layer 1 OSI Model) can take on several different forms. The preferred and most prevalent implementation of the Physical Layer (Layer 1 OSI Model) is the RS-485 (TIA/EIA-485), RS-232 (TIA/EIA-232-E) are also common, Modbus can even be implemented over TCP/IP on the Ethernet (IEEE 802.3) Physical Layer.
    So your question,
    depends solely on the makeup of the Physical Layer the Modbus Datalink Layer is implemented over.
    MODBUS over serial line specification and implementation guide V1.02
    MODBUS MESSAGING ON TCP/IP IMPLEMENTATION GUIDE V1.0b
    MODBUS APPLICATION PROTOCOL SPECIFICATION V1.1b
    Modbus Organization
    Modbus Related Technical Resources
    I believe the circuit you're referring to provides fail-safe biasing, proper termination and transient protection.
    RS-485/RS-422 Circuit Implementation Guide
    Hope the info helps you with your implementation.
    1 members found this post helpful.
  8. #8
    Full Member level 5
    Achievements:
    7 years registered
    cool.man's Avatar
    Join Date
    May 2008
    Earth
    Posts
    314
    Points
    3,726
    Level
    14
    Actually i am confused about the voltages levels by seeing this link
    http://zone.ni.com/cms/images/devzon...3349fd4155.gif
    Tell me about that
  9. #9
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    The "RS-485" levels shown in the said paper are at best typical voltage levels, but not actually related to the RS-485 specification, that mainly focusses on required differential signalling levels and maximum common mode voltage. That't the problem when referring to unqualified internet resources.
    Honestly, I don't understand which problem you are chasing behind?
    •   Alt13th June 2011, 08:30
      advertising
  10. #10
    Full Member level 5
    Achievements:
    7 years registered
    cool.man's Avatar
    Join Date
    May 2008
    Earth
    Posts
    314
    Points
    3,726
    Level
    14
    Simply I wanna know that for protection what would be the theme at pin 6 and 7 of this IC.
  11. #11
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    You have to distinguish between send and receive levels. Send levels are simply limited by the driver supply voltage, receive levels can be higher due to superimposed common mode voltages. 6.8V TVS diodes, as shown in the attachment of post #4 are a reasonable choice in my opinion.
