+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Newbie level 6
    Points: 327, Level: 3
    Join Date
    May 2011
    India
    Posts
    11
    Points
    327
    Level
    Help for interfacing LM35 on atmega16
    I am presently trying to build up a project on a temperature sensor with the help of LM35DZ using an atmega16 uC and trying to display the result on a 16x2 LCD...I have compiled a code but its not working(since I'm a complete noob)...I am posting the code in this thread..Please correct me,any help will be highly appreciated..
    __________________________________________________ __
    #include <mega16.h>
    #include <delay.h>
    #include <stdio.h>
    #include <lcd.h>
    #asm
    .equ __lcd_port=0x18 ;PORTB
    #endasm
    #define ADC_VREF_TYPE 0x60
    unsigned int i;
    unsigned char j;
    unsigned char adc_val;
    unsigned int adc_volt;
    void adc_test()
    for(j=0;j<3;j++)
    for(i=0;i<6;i++)
    adc_val = read_adc(i);
    adc_volt = (adc_val * 195.3)/10;
    delay_ms(500);
    void main()
    unsigned char rows=2;
    unsigned char cols=16;
    lcd_init(cols);
    lcd_clear();
    lcd_gotoxy((cols/2)-6,(rows/2)-1);
    lcd_putsf("Temp Reading=");
    lcd_gotoxy((cols/2)-3,(rows/2));
    lcd_putsf("adc_volt");
    __________________________________________________ ___
    •   Alt25th May 2011, 09:23
      advertising
  2. #2
    Advanced Member level 5
    Points: 33,613, Level: 44
    ckshivaram's Avatar
    Join Date
    Apr 2008
    villingen (Germany) / Bangalore
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    Re: Help for interfacing LM35 on atmega16
    " It is so simple to be happy,
    but it is so difficult to be simple"
  3. #3
    Administrator
    Points: 37,969, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,969
    Level
    47
    Blog Entries
    Quote Originally Posted by a4arijit View Post
    Which compiler did you try?
    It will not work in AVR-GCC (winavr) , your code is written for codevisionAVR
    Alex
    •   Alt25th May 2011, 14:04
      advertising
  4. #4
    Newbie level 6
    Join Date
    May 2011
    India
    Posts
    11
    Points
    327
    Level
    Quote Originally Posted by ckshivaram View Post
    http://www.8051projects.net/e107_fil...FT37769_cd.png[COLOR="Silver"]
    ---------- Post added at 11:59 ---------- Previous post was at 11:58 ----------
    Quote Originally Posted by alexan_e View Post
    Alex
    I compiled it with CVAVR...the error its generating is that "pointer to the function 'adc_val = read_adc(i);' must be written"
    •   Alt26th May 2011, 06:29
      advertising
  5. #5
    Administrator
    Achievements:
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,969
    Level
    47
    Blog Entries
    There is no read_adc(); in codevision and you haven't included any such function in your code too.
    You also haven't included any initialization code for the ADC (REF source, ADC clock etc.), use the codewizard to generate the initialization file and then add you code.
    Alex
  6. #6
    Newbie level 6
    Join Date
    May 2011
    India
    Posts
    11
    Points
    327
    Level
    This program was produced by the
    CodeWizardAVR V2.03.4 Standard
    Automatic Program Generator
    © Copyright 1998-2008 Pavel Haiduc, HP InfoTech s.r.l.
    HP InfoTech, Development Tools for Microcontrollers, C Compilers, In-System Programmers
    Project :
    Version :
    Date : 6/11/2011
    Author :
    Company :
    Comments:
    Chip type : ATmega16
    Program type : Application
    Clock frequency : 16.000000 MHz
    Memory model : Small
    External RAM size : 0
    Data Stack size : 256
    #include <mega16.h>
    // Alphanumeric LCD Module functions
    #asm
    #endasm
    #include <lcd.h>
    #include <delay.h>
    #define ADC_VREF_TYPE 0x00
    // Read the AD conversion result
    unsigned int read_adc(unsigned char adc_input)
    ADMUX=adc_input | (ADC_VREF_TYPE & 0xff);
    // Delay needed for the stabilization of the ADC input voltage
    delay_us(10);
    // Start the AD conversion
    ADCSRA|=0x40;
    // Wait for the AD conversion to complete
    while ((ADCSRA & 0x10)==0);
    ADCSRA|=0x10;
    return ADCW;
    // Declare your global variables here
    void main(void)
    // Declare your local variables here
    // Input/Output Ports initialization
    // Port A initialization
    // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
    // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
    PORTA=0x00;
    DDRA=0x00;
    // Port B initialization
    // Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
    // State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
    PORTB=0x00;
    DDRB=0xFF;
    // Port C initialization
    PORTC=0x00;
    DDRC=0x00;
    // Port D initialization
    PORTD=0x00;
    DDRD=0x00;
    // Timer/Counter 0 initialization
    // Clock source: System Clock
    // Clock value: Timer 0 Stopped
    // Mode: Normal top=FFh
    // OC0 output: Disconnected
    TCCR0=0x00;
    TCNT0=0x00;
    OCR0=0x00;
    // Timer/Counter 1 initialization
    // Clock value: Timer 1 Stopped
    // Mode: Normal top=FFFFh
    // OC1A output: Discon.
    // OC1B output: Discon.
    // Noise Canceler: Off
    // Input Capture on Falling Edge
    // Timer 1 Overflow Interrupt: Off
    // Input Capture Interrupt: Off
    // Compare A Match Interrupt: Off
    // Compare B Match Interrupt: Off
    TCCR1A=0x00;
    TCCR1B=0x00;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x00;
    OCR1BH=0x00;
    OCR1BL=0x00;
    // Timer/Counter 2 initialization
    // Clock value: Timer 2 Stopped
    // OC2 output: Disconnected
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00;
    // External Interrupt(s) initialization
    // INT0: Off
    // INT1: Off
    // INT2: Off
    MCUCR=0x00;
    MCUCSR=0x00;
    // Timer(s)/Counter(s) Interrupt(s) initialization
    TIMSK=0x00;
    // Analog Comparator initialization
    // Analog Comparator: Off
    // Analog Comparator Input Capture by Timer/Counter 1: Off
    ACSR=0x80;
    SFIOR=0x00;
    // ADC initialization
    // ADC Clock frequency: 250.000 kHz
    // ADC Voltage Reference: AREF pin
    // ADC Auto Trigger Source: None
    ADMUX=ADC_VREF_TYPE & 0xff;
    ADCSRA=0x86;
    // LCD module initialization
    lcd_init(16);
    while (1)
    // Place your code here
    ---------- Post added at 15:09 ---------- Previous post was at 15:08 ----------
    In this code i cant find the integer which the ADC has converted and display it on the LCD..
  7. #7
    Administrator
    Achievements:
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,969
    Level
    47
    Blog Entries
    you have to call the function below and the result is returned by the function
    [syntax=c]
    delay_us(10);
    ADCSRA|=0x40;
    ADCSRA|=0x10;
    return ADCW;
    // for example
    unsigned int my_adc_result; // variable to store the result
    my_adc_result = read_adc(0); // make the conversion for channel 0 and read the result
    [/syntax]
    Alex
    1 members found this post helpful.
  8. #8
    Points: 38,206, Level: 47
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    The integer is ADCW. In the function:
    [syntax=c]
    delay_us(10);
    ADCSRA|=0x40;
    ADCSRA|=0x10;
    return ADCW;
    // for example
    [/syntax]
    The integer is returned when called. The returned integer is ADCW. When you do something like this:
    The integer is assigned to my_adc_result. So, my_adc_result contains the value that the ADC has converted.
    Hope this helps.
    Tahmid.
  9. #9
    Member level 4
    Points: 1,627, Level: 9
    herlambang's Avatar
    Join Date
    Apr 2009
    Indonesia
    Posts
    74
    Points
    1,627
    Level
    9
    This is my program using ATmega16 and CodevisionAVRCompiler.
    I'm sorry the program explanation using Indonesian language, but this program is work.
    About Program:
    Program LM35 AVR ADC 10bit  :)
    Program ini akan menampilkan temperature dengan satuan CELCIUS yang didapat
    dari sensor temperature LM35. LM35 dihubungkan ke PINA.0 atau ADC 0
    dalam aplikasi real, mungkin diperlukan buffer dan bisa dibuat dari
    opamp single supply misal LM358. Jangan lupa kalo mo dibuat beneran, PIN AVCC
    ADC dihubungkan ke 5V yg stabil, terus PIN AREF dikasih BYPASS CAPASITOR ke GND
    100nF sudah cukup.
    perhitungan pake 1024 (jumlah total data 10bit) dan bukan 1023 (jumlah maksimal
    data dari 10bit). Dibaca aja di keterangan dalam program..
    Happy Programming^^
    Herlambang Aribowo
    Compiler: CodeVisionAVR V2.03.9
    Chip    : ATmega16 X-tall 4Mhz
    FUSE: H:C9 L:2F  Brownout@4.5V,WDT ON,BOD ON,SPI EN,X-tall High Freq.
    FUSE: H:C9 L:AF  Brownout@2.7V,WDT ON,BOD ON,SPI EN,X-tall High Freq.
    #include <mega16.h>
    #include <delay.h>
    #include <stdio.h>
    #asm
       .equ __lcd_port=0x15 ;PORTC
    #endasm
    #include <lcd.h>
    #define ADC_VREF_TYPE 0xC0 //Internal
    unsigned char buffer[16]; //Untuk buffer sprintf
    float temperature; //Untuk data perhitungan temperature (float)
    unsigned int temporary; //Untuk temporary data ADC (komparasi)
    void updatetemp(void);//Fungsi untuk pengolahan data ADC ke temperature
    void sett_regs(void); //Fungsi untuk setting register di awal proses
    unsigned int read_adc(unsigned char adc_input);//Fungsi baca ADC
    // Main function
    void main(void){
    //--------------- Setting IO and peripheral at startup!
    sett_regs();
    _lcd_ready();
    //--------------- Time for going CRAZY (looping forever)..
    for(;;){ //mainloop looping forever until ERROR/POWER SHUTDOWN/RST/WDT ACTIVE
        #asm("wdr") //kick your DOG before DEAD! hwahwa... :D
        updatetemp();
        #asm("nop")
    void updatetemp(void){
    if (temporary != read_adc(0)){//bila ada data baru, tampilkan
        //ADC = ( Vin * 1024 / Vref )
        //misal, temperature LM35 = 30°C, Vin = 300mV = 0.3V,
        //jadi nilai ADC = (.3*1024/2.56)=120, 120/30 = 4
        //Persamaan bisa disederhanakan dengan output data ADC/4
        temperature = read_adc(0)/4; //hanya untuk Vref 2.56
        lcd_gotoxy(0,0);
        lcd_putsf("WWW.NUBIELAB.COM");
        lcd_gotoxy(0,1);
        sprintf(buffer,"SUHU: %0.1f%cC  ",temperature,0xDF);
        lcd_puts(buffer);
        temporary = read_adc(0);
        delay_ms(100);
    // Function for setting register
    void sett_regs(void){
    // Port a initialization
    PORTA=0x00;DDRA=0x00;
    // Port b initialization
    PORTB=0x00;DDRB=0x00;
    // Port c initialization
    PORTC=0x00;DDRC=0x00;
    PORTD=0x00;DDRD=0x00;
    // ADC Clock frequency: 1000.000 kHz
    // ADC Voltage Reference: AVCC pin
    // ADC Auto Trigger Source: Free Running
    ADCSRA=0xA2;
    SFIOR&=0x1F;
    lcd_init(16);
    ACSR=0x80;
    SFIOR=0x00;
    // Watchdog Timer initialization
    // Watchdog Timer Prescaler: OSC/2048k
    #pragma optsize-
    WDTCR=0x1F;
    WDTCR=0x0F;
    #ifdef _OPTIMIZE_SIZE_
    #pragma optsize+
    #endif
    // Routine baca ADC
    // Jangan lupa AVCC ke +5V biar ADCnya bekerja :D
    // Connected a 0.1uF bypass capacitor at AREF pin as per datasheet,
    // “Internal 2.56V Voltage Reference with external capacitor at AREF pin”.
    unsigned int read_adc(unsigned char adc_input){
    delay_us(10);
    ADCSRA|=0x40;
    ADCSRA|=0x10;
    return ADCW;
    You can download complete file project and C source and also simulation file (Proteus ISIS) in attached file. You can open the .dsn file using Proteus ISIS Version 7.4Sp3 or later.
    Below is an image captured from Proteus ISIS simulation, please click to enlarge.
    Click image for larger version.
    source: AVR Digital Thermometer LM35 – CodeVisionAVR | www.nubielab.com
    Happy programming.. :D
    Regards,
    Herlambang Aribowo.
    Built in double watchdog! *problem solved*
    2 members found this post helpful.
  10. #10
    Newbie level 6
    Join Date
    May 2011
    India
    Posts
    11
    Points
    327
    Level
    #include <mega16.h>
    #include <delay.h>
    #include <stdio.h>
    #include <math.h>
    #asm
    #endasm
    #include <lcd.h>
    #define ADC_VREF_TYPE 0x00 //Internal
    unsigned char buffer[16]; //To the buffer sprintf
    int temperature; //For the calculation of temperature data (float)
    unsigned int temporary; //ADC for temporary data (comparison)
    void updatetemp(void);//Functions for processing the ADC data to the temperature
    void sett_regs(void); //Function for setting the registers at the beginning of the process
    // Main function
    void main(void){
    sett_regs();
    _lcd_ready();
    updatetemp();
    #asm("nop")
    if (temporary != read_adc(1))
    //example, temperature LM35 = 30°C, Vin = 300mV = 0.3V,
    //so the value ADC = (.3*1024/5)=61.44, 61.44/30 = 2.048
    //The equation can be simplified by output data ADC/2.048
    temperature = read_adc(1)/2.048; //only for Vref 5
    lcd_gotoxy(2,0);
    lcd_putsf("Temperature=");
    lcd_gotoxy(6,1);
    sprintf(buffer,"%d%cC",temperature,0xDF);
    lcd_puts(buffer);
    temporary = read_adc(1);
    delay_ms(100);
    ADCSRA=0xA2;
    SFIOR&=0x1F;
    lcd_init(16);
    ACSR=0x80;
    SFIOR=0x00;
    #pragma optsize-
    WDTCR=0x1F;
    WDTCR=0x0F;
    #pragma optsize+
    #endif
    // Routine baca ADC
    delay_us(10);
    ADCSRA|=0x40;
    ADCSRA|=0x10;
    return ADCW;
    ---------- Post added at 14:34 ---------- Previous post was at 14:29 ----------
    This is the working program for Lm35 with Atmega16 using its external 16MHz crystal oscillator..The ADC voltage ref is the AREF pin having 5.1v...I've converted the indonesian to english...the program works fine but i am unable to print the value on float point..so i had to assign integer for the variable..when the variable is assigned as a float it tends to print a result "1f"...but can anyone help me on printing the value as a float???
    ---------- Post added at 14:37 ---------- Previous post was at 14:34 ----------
    And really thanx to "herlambang","Tahmid" and "alexan_e" for their help...
    •   Alt26th June 2011, 09:07
      advertising
  11. #11
    Administrator
    Achievements:
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,969
    Level
    47
    Blog Entries
    In this code
            temperature = read_adc(1)/2.048; //only for Vref 5  // NOTE1
            lcd_gotoxy(2,0);
            lcd_gotoxy(6,1);
            lcd_puts(buffer);
            delay_ms(100);
    NOTE1
    The division result is stored in an integer so you will get 0 in almost any result [EDIT I was wrong, I thought you were dividing with 2048, I just noticed it was 2.048], you can either use float to store and show the result or you can multiply the result with a value like 10000 and then store the result to an integer
    in your case a simple read_adc(1)/2 can give the temperature (5v reference), take a look Interfacing Temperature Sensor with AVR Microcontrollers - LM35 | eXtreme Electronics
    When you want to use the float version of sprintf go to project -> configure -> c compiler and change sprintf features to float,width.precision
    The multiplication method is much better because it uses less resources but you can do any of them.
    Alex
  12. #12
    Newbie level 6
    Join Date
    May 2011
    India
    Posts
    11
    Points
    327
    Level
    Thanks again alexan_e...It worked.Changing the variable types at project configuration did the job...I am posting the final code which actually works along with all the settings..
    Settings::
    Chip:Atmega16
    Clock:16MHz
    ADC Channel:2nd ADC channel is used
    ADC frequency:250KHz (Use this frequency for precision)
    Reference voltage for ADC:AREF pin (5v)
    LCD Port:PortB
    Compiler:CodeVisionAVR
    HEX file burner:eXtreme Burner
    Code :
    #include <mega16.h>
    #include <delay.h>
    #include <stdio.h>
    #include <math.h>
    #asm
    #endasm
    #include <lcd.h>
    unsigned char buffer[16]; //For sprintf buffer
    unsigned char bufferr[16];
    float temperature; //For the calculation of temperature data (float)
    float temperaturef;
    unsigned int read_adc(unsigned char adc_input);//Read ADC function
    // Main function
    void main(void){
    sett_regs();
    _lcd_ready();
    updatetemp();
    #asm("nop")
    //Example, temperature LM35 = 30°C, Vin = 300mV = 0.3V,
    //so the value ADC = (.3*1024/5.1)=60.235, 60.235/30 = 2.007
    //The equation can be simplified by output data ADC/2.007
    temperature = read_adc(1)/2.007; //only for Vref 5.1
    temperaturef = ((9*temperature)/5)+32; // for fahrenheit conversion
    lcd_gotoxy(2,0);
    lcd_putsf("Temperature");
    lcd_gotoxy(1,1);
    sprintf(buffer,"%0.1f%cC",temperature,0xDF); //0xDF is for printing degree
    lcd_puts(buffer);
    lcd_gotoxy(9,1);
    sprintf(bufferr,"%0.1f%cF",temperaturef,0xDF);
    lcd_puts(bufferr);
    delay_ms(100);
    ADCSRA=0x86;
    SFIOR&=0x1F;
    lcd_init(16);
    ACSR=0x80;
    SFIOR=0x00;
    #pragma optsize-
    WDTCR=0x1F;
    WDTCR=0x0F;
    #pragma optsize+
    #endif
    // Routine read ADC
    // Do not forget to supply +5 V to AREF to work
    delay_us(10);
    ADCSRA|=0x40;
    ADCSRA|=0x10;
    return ADCW;
    ---------- Post added at 21:13 ---------- Previous post was at 21:11 ----------
    Hope others find this thread useful...Thankyou all..
