+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Full Member level 2
    Points: 3,120, Level: 13
    Join Date
    May 2004
    Posts
    144
    Points
    3,120
    Level
    13
    reciprocity theorem
    Guyz, what is Reciprocity theorem?
  2. #2
    Newbie level 5
    Points: 1,601, Level: 9
    Join Date
    Jun 2004
    Canada
    Posts
    10
    Points
    1,601
    Level
    9
    reciprocity theorem in network analysis
    http://www.du.edu/~jcalvert/tech/reciproc.htm
    In its simplest form, the reciprocity theorem states that if an emf E in one branch of a reciprocal network produces a current I in another, then if the emf E is moved from the first to the second branch, it will cause the same current in the first branch, where the emf has been replaced by a short circuit. We shall see that any network composed of linear, bilateral elements (such as R, L and C) is reciprocal.
    I really feel for those in the world that are restricted from completing a google search.
    asd913
    •   Alt19th July 2004, 06:13
      advertising
  3. #3
    Member level 1
    Points: 1,727, Level: 9
    Join Date
    May 2004
    Posts
    41
    Points
    1,727
    Level
    9
    what is reciprocity
    It is do unto those that do unto you
    1 members found this post helpful.
    •   Alt26th July 2004, 11:01
      advertising
  4. #4
    Junior Member level 1
    Points: 1,632, Level: 9
    Join Date
    May 2004
    Posts
    18
    Points
    1,632
    Level
    9
    reciprocity theorem
    there is a more general formulation of reciprocity in science ...
    If You have a property, lets say 'Y' which depends on parameters X1, X2 ...
    then:
    Y = f(X1,X2 ... Xn) describes the forward problem
    while computation of:
    X1 = g(Y,X2...Xn) describes one inverse problem
    were Y, Xi are Vectors of arbitrary dimensionality.
    Examples are the determination of 'sources' for the magnetic field (electromagnetism) and gravitation (geophysics).Typically the inverse
    problem is nonunique and solvable only through additional constraints.
    HTH, RoZ
    •   Alt26th July 2004, 12:09
      advertising
  5. #5
    Junior Member level 3
    Points: 1,646, Level: 9
    Join Date
    Jul 2004
    Posts
    27
    Points
    1,646
    Level
    9
    reciprocity theorem
  6. #6
    Full Member level 2
    Points: 2,578, Level: 11
    Join Date
    May 2004
    Posts
    144
    Points
    2,578
    Level
    11
    theorem of reciprocity
    hi
    A reciprocity theorem is presented that relates the short-circuit current of a device, induced by a carrier generation source, to the minority-carrier Fermi level in the dark.^The basic relation is general under low injection.^It holds for three-dimensional devices with position dependent parameters (energy gap, electron affinity, mobility, etc.), and for transient or steady-state conditions.^This theorem allows calculation of the internal quantum efficiency of a solar cell by using the analysis of the device in the dark.^Other applications could involve measurements of various device parameters, interfacial surface recombination velocity at a polycrystalline silicon emitter contact, for example, by using steady-state or transient photon or mass-particle radiation
    http://mathworld.wolfram.com/ReciprocityTheorem.html
    http://www.phy.mtu.edu/~dfnitz/fall9...ure/node3.html
    taring
  7. #7
    Points: 1,372, Level: 8
    Join Date
    Jun 2005
    Posts
    7
    Points
    1,372
    Level
    8
    reciprocity theorem problems
    In physical sense.....suppose A does Job1 and B does Job2 and jobs are done..
    even if A and B are interchanged and jobs are done , we say that A and B obeys reciprocity........technically, if source and load in a network can be interchanged without change in the network characteristics, it obeys reciprocity....
  8. #8
    Full Member level 3
    Points: 2,614, Level: 11
    Join Date
    Oct 2004
    Posts
    169
    Points
    2,614
    Level
    11
    reciprocity theorem circuit theory
    In circuit theory the reciprocity theorem is very useful.
    It states that ,any linear network consisting of more than one sources and other bilateral circuit element,if u interchange the sources.then response will be same.ie any two port n/w, if response due to a excitation is known and if source and excitation r interchange then effect will be same.
    •   Alt19th June 2005, 15:07
      advertising
  9. #9
    Points: 1,511, Level: 8
    Join Date
    Jun 2005
    Posts
    29
    Points
    1,511
    Level
    8
    questions based on reciprocity theorem
    In very basic sense A reciprocity theorem states that:
    If the ratio of excitation to response is invariant to an interchange in the positions of excitation and response in the network then the network is said to be a Reciprocal Network..
    Seems as if m givin a theory paper...
  10. #10
    Newbie level 2
    Points: 1,472, Level: 8
    Join Date
    Oct 2004
    Posts
    Points
    1,472
    Level
    8
    what is reciprocity
    check the book BASIC CIRCUIT THEORY by Charles A. Desoer
