panos_papajohn
Member level 2
Hi everyone,
I wrote a VHDL script for interfacing the DAC on the Spartan3E board with the FPGA. When I am running the synthesis tool I get the following warning : WARNING:Xst:1293 - FF/Latch <SPI_signal_0> has a constant value of 0 in block <SPI>. This FF/Latch will be trimmed during the optimization process.
I don't get why since I have gave a value to this signal. I need to fix this cause the simulation doesn't work correctly. This is the code :
If anyone could help my I would appreciate it. AS you can tell Im to VHDL so be patient please:grin:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity SPI is
port(clk, ALOAD : in std_logic;
D : in std_logic_vector(11 downto 0);
SO : out std_logic;
clock_out : OUT STD_LOGIC;
chip_select : OUT STD_LOGIC);
end SPI;
architecture archi of SPI is
signal SPI_signal: std_logic_vector(31 downto 0) := (others => '0');
signal data1 : std_logic_vector (11 downto 0):= (others => '0');
signal clock : std_logic ;
begin
process (clk, ALOAD, data1,SPI_signal,D)
variable chip : std_logic;
begin
-- Shift registers implements the SPI communication
if (ALOAD='0') then
--Disable DAC
chip :='0';
chip_select <= chip;
data1<=D;
--Create the data stream for the ADC on the SPARTAN3E board.
SPI_signal <= "1010"& data1 & "0000" & "0011" & "10101010";
elsif (clk'event and clk='1') then
SPI_signal <= SPI_signal(30 downto 0) & '0';
SO <= SPI_signal(31);
--Enable DAC for the data conversion
chip :='1';
end if;
end process;
--Clock output for the DAC
clock<=clk;
clock_out <= clock;
end archi;
