+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Junior Member level 2
    Points: 425, Level: 4
    Join Date
    Mar 2011
    North Dakota
    Posts
    21
    Points
    425
    Level
    Simple Morse Code Transmitter
    Hey can anyone tell me if this will work as a very simple morse code transmiter?
    Click image for larger version.
Name:	New Bitmap Image.jpg
    Of course if not could someone help me?
    And if it does whats the equation for how far ill be able to transmit?
    One more thing, how can i recieve it?
    Thanks for the help.
  2. #2
    Advanced Member level 3
    Points: 4,815, Level: 16
    Achievements:
    7 years registered
    KJ6EAD's Avatar
    Join Date
    Oct 2010
    Earth
    Posts
    709
    Points
    4,815
    Level
    16
    Re: Simple Morse Code Transmitter
    You can build a simple morse code transmitter that can be received by a regular AM or FM radio. I seem to remember seeing schematics for these in some of the Forrest Mims books.
    It would be helpful to know how far you want to transmit and if you care what kind of parts are in the circuit (tubes, transistors, ICs, etc.). Do you intend to build the receiver or use an off-the-shelf radio?
    By the way, you should consider posting this on eham.net in the "homebrew" category.
    •   Alt14th May 2011, 23:34
      advertising
  3. #3
    Super Moderator
    Points: 25,592, Level: 38
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,698
    Points
    25,592
    Level
    38
    Blog Entries
    Fworg
    That picture is an intersting application of the simplest broadcast transmitter called Galena. Requires few amount of electronic components. Repair that no intermediate frequency is used.
    However this kind of transmitter takes a wide band of RF spectrum and may be considered just for emergency purposes. At normal operation you should work under hiperheterodine topology circuit.
    If you intend operate this equipment need perform a survey at your country regulations regarding what are the free use radio frequency spectrum ranges.
    Answering your question : The receiver you can build also simply like bellow :
    1 members found this post helpful.
    •   Alt15th May 2011, 00:03
      advertising
  4. #4
    Join Date
    Mar 2011
    North Dakota
    Posts
    21
    Points
    425
    Level
    So if i build on of these
    and one of these
    I should have a transmitter and a receiver.
    could someone please elaborate how exactly the inductor is connected to the spark gap?
    Thank you for your help
    EDIT:: found simpler diagrams
    •   Alt15th May 2011, 05:17
      advertising
  5. #5
    Super Moderator
    Points: 69,588, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,375
    Points
    69,588
    Level
    64
    Oh no! I'm just glad North Dakota is a long way from here.
    @Fworg64 this is exactly waht Marconi used in the very first 'wireless' broadcast. Spark transmitters are VERY broad band, you don't tune into them as such because they produce a signal which covers the whole band and these days would be regarded as interference. They also don't produce Morse Code in the accepted sense, you will not hear dots and dashes or even a tone, just a clicking noise. You would do far better to look at simple keyed oscillators which you can pick up on a domestic radio. Even a simple single transistor oscillator will have tens, maybe hundreds of times the range and it will produce a continuous signal when the key is held down rather than a single click as it is released.
    Brian.
  6. #6
    Super Moderator
    Join Date
    Nov 2006
    Brazil
    Posts
    7,698
    Points
    25,592
    Level
    38
    Blog Entries
    Quote Originally Posted by betwixt View Post
    ...they produce a signal which covers the whole band and these days would be regarded as interference...
    A perfect definition of above circuit : Noise generator !
  7. #7
    Creativeguy024
    HOPE THIS HELPS.
  8. #8
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,375
    Points
    69,588
    Level
    64
    Hmmm....
    How far will that transmit?
    Brian.
    •   Alt16th May 2011, 11:07
      advertising
  9. #9
    Creativeguy024
    ]IT WORKED AT AROUND 100m RANGE FOR ME. (when coupled with antenna)
  10. #10
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,375
    Points
    69,588
    Level
    64
    The original post is for a radio transmitter, you show an audio oscillator. It may well radiate interference if an antenna is attached but only due to harmnics of the NE555 output.
    What is being suggested is a keyed RF oscillator that can be tuned on a normal AM radio.
    Brian.
  11. #11
    Creativeguy024
    Thanks Brian...:) This was a thing which i tried out sometime back.. u are correct.. this is (for) by using an audio oscillator.. :P Well.. I hope the code info was helpful. Take Care..:)
