+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Points: 12,051, Level: 26
    Achievements:
    Created Blog entry 7 years registered
    thannara123's Avatar
    Join Date
    Jan 2010
    Nedumkandam, India, India
    Posts
    1,404
    Points
    12,051
    Level
    26
    Blog Entries
    a good circuit whic convert 12volt DC to 24 Volt Dc
    My friend asked me to design / make a circuit ,a DC to DC converter that is 12 volt Dc to 24 Volt dc how can i ,the 24 volt will connect to optical receiver ( in which has a circuits with BGY 887 IC)
    I Respect You
    •   Alt14th May 2011, 16:59
      advertising
  2. #2
    Full Member level 6
    Points: 2,120, Level: 10
    Join Date
    Aug 2010
    delhi
    Posts
    323
    Points
    2,120
    Level
    10
    Re: a good circuit whic convert 12volt DC to 24 Volt Dc
    Use a topswitch with series inductance to generate step up voltage.
    The design of inductor values can be got from Power integration Inc. or fairchild .There is no isolation as the ground is common.What is the actual load currents handled at 24VDC?What are the loads being driven,,will the switching noise have relevance?
    •   Alt14th May 2011, 17:22
      advertising
  3. #3
    Advanced Member level 5
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    1 members found this post helpful.
    •   Alt14th May 2011, 19:12
      advertising
  4. #4
    Full Member level 6
    Join Date
    Aug 2010
    delhi
    Posts
    323
    Points
    2,120
    Level
    10
    The pushpull complementary stages are balanced but have their difference in the Hfe of the devices which causes one of them to saturate and drive other into cutoff.The phase reversed secondary has a ratio 1:4 which gives 3VDC pulse at the base drive of the OFF device and switches it ON.The resonant secondary inductance with the 100nF and static capacitance of load provide the frequency of propagation in the base drive ..The Q2 saturates and this drives Q1 into cutoff owing to phase reversal windings....The process repeats to generate 2x12VDC square switching .The transition time is small and gives perfect square wave with no losses or overshoots in the in the peak to peak performance of output .
    As such ,need for snubbers does not arise to damp out ringing ..However , the Bmax of the ferrites needs to be 3000..
    For 50watt conversion the size needed is EE30 with N67 --87 cores .
