+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 3
    Points: 2,646, Level: 11
    Achievements:
    7 years registered
    tahir4awan's Avatar
    Join Date
    Nov 2010
    Posts
    183
    Points
    2,646
    Level
    11
    Pic16f887 eeprom read/write
    I wrote a simple code to write and read data from EEPROM. The code is working
    for all ports except PORTB. What is the problem?
    void main(){
    ANSEL = 0; // Configure AN pins as digital I/O
    ANSELH = 0;
    C1ON_bit = 0; // Disable comparators
    C2ON_bit = 0;
    TRISB = 0x00;
    PORTB = 0x00;
    EEPROM_Write(0x50,0xAA);
    Delay_ms(1000);
    PORTB = EEPROM_Read(0x50);
    Secondly MikroC uses its own built in functions
    EEPROM_Read(0x50);
    and PIC microcontroller has EECON1 and EECON2 registers. What is the difference?
    •   Alt10th May 2011, 02:19
      advertising
  2. #2
    Full Member level 4
    Points: 2,455, Level: 11
    Join Date
    Oct 2008
    Posts
    238
    Points
    2,455
    Level
    11
    Re: Pic16f887 eeprom read/write
    you need to prevent the mcu from going into sleep state, add an infinite loop at the main procedure, something like this.
    void main()
    procedure1();
    do{
    } While(TRUE);
    When the MCU goes into sleep, the program execution stops, so to keep the mcu busy you need to give it work.
  3. #3
    Full Member level 1
    Points: 1,831, Level: 9
    bjuric's Avatar
    Join Date
    May 2011
    Serbia
    Posts
    115
    Points
    1,831
    Level
    9
    Check the datasheet.
    EECON1 contains EEPROM contol bits
    EECON2 does not exist physically. That's a virtual register in which you need to write 0x55 and 0xAA (one after the other) before initiating EEPROM write. It serves as a protection from accidental writing into EEPROM. EEPROM_Write() does that for you.
    •   Alt10th May 2011, 11:49
      advertising
  4. #4
    Full Member level 3
    Achievements:
    7 years registered
    tahir4awan's Avatar
    Join Date
    Nov 2010
    Posts
    183
    Points
    2,646
    Level
    11
    My point is the same code is working for all ports but not for PORTB. It means code is correct.
  5. #5
    Full Member level 4
    Points: 3,111, Level: 13
    Achievements:
    7 years registered
    thunderboympm's Avatar
    Join Date
    Sep 2007
    Malappuram, India
    Posts
    225
    Points
    3,111
    Level
    13
    assign the eeprom value to a variable and then to portb. I got same error, i solved like this. Don't ask me the theory behind this i don't know
    •   Alt11th May 2011, 02:03
      advertising
  6. #6
    Full Member level 3
    Achievements:
    7 years registered
    tahir4awan's Avatar
    Join Date
    Nov 2010
    Posts
    183
    Points
    2,646
    Level
    11
    thunderboympm I think you have become angry but Thanks for your help.
  7. #7
    Full Member level 4
    Achievements:
    7 years registered
    Join Date
    Sep 2007
    Malappuram, India
    Posts
    225
    Points
    3,111
    Level
    13
    no, i am not angry my friend. I donot know why is this.
