+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Junior Member level 3
    Points: 1,639, Level: 9
    Achievements:
    7 years registered
    Join Date
    Jan 2010
    TEHRAN
    Posts
    29
    Points
    1,639
    Level
    9
    PIC18F452 Timers/Counters Interrupts,...
    Hello everybody.I want to write a program using PIC18F452&XTAL=20MHZ in C or mikroC to do the followings;
    1.Simultaneously turn a timer on[timer0 or...] to count for 1 sec. and
    also count the number of High[transition from H to L] state of the
    input signal.
    2.Turn a timer on[timer0 or...] for 1 sec. and as soon as a input signal injected or entered to a PIC pin the timer[timer0 or...]immediately turned off and calculate the time of passed by that timer.
    Would you please help and give me some example codes to write those programs?
    Thanks,
    •   Alt23rd April 2011, 20:48
      advertising
  2. #2
    Administrator
    Points: 69,113, Level: 64
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,113
    Level
    64
    Blog Entries
    Re: PIC18F452 Timers/Counters Interrupts,...
    Here's examples of interrupt and timer use:
    PIC Interrupts - Part 1
    PIC16F877 Timer Modules tutorials
    Introduction to PIC18′s Timers
    Interrupts - Writing The Code
    The above examples are have similarities to both your scenarios.
    Scenario 1 uses an external interrupt edge transition or external clock input and timer overflow interrupt.
    Scenario 2 uses an external interrupt edge transition and timer overflow interrupt.
    Hope the info helps in your endeavors.
