+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 1
    Points: 306, Level: 3
    Join Date
    Apr 2011
    Posts
    Points
    306
    Level
    230VAC to 12VDc converter circuit
    hi
    any one shall help me to come out the problem.
    i want to build 230VAC to 12VDC circuit without transformer.
    i need the circuit diagram and description.
    regards
    G R Patil
    •   Alt23rd April 2011, 10:10
      advertising
  2. #2
    Junior Member level 1
    Points: 364, Level: 4
    Join Date
    Apr 2011
    Posts
    16
    Points
    364
    Level
    Re: 230VAC to 12VDc converter circuit
    I think transformer is better one of this conversion..
    2 members found this post helpful.
    •   Alt23rd April 2011, 11:10
      advertising
  3. #3
    Super Moderator
    Points: 50,313, Level: 54
    Achievements:
    7 years registered
    erikl's Avatar
    Join Date
    Sep 2008
    Germany
    Posts
    7,874
    Points
    50,313
    Level
    54
    •   Alt23rd April 2011, 12:12
      advertising
  4. #4
    Points: 10,068, Level: 24
    leo_o2's Avatar
    Join Date
    Sep 2004
    China
    Posts
    1,324
    Points
    10,068
    Level
    24
    You need AC-DC flyback converter if high efficiency is required.
  5. #5
    Newbie level 5
    Points: 1,615, Level: 9
    Achievements:
    7 years registered
    Join Date
    Apr 2008
    Croatia
    Posts
    8
    Points
    1,615
    Level
    9
    Perhaps an old AT/ATX PC powersupply could help?
    1 members found this post helpful.
  6. #6
    Member level 2
    Points: 949, Level: 6
    saikat36's Avatar
    Join Date
    Mar 2011
    Posts
    46
    Points
    949
    Level
    Quote Originally Posted by Zez View Post
    Nice suggestion indeed.
    You don't have to know everything, if you know where to find it.
  7. #7
    Member level 4
    Points: 708, Level: 5
    Join Date
    Apr 2011
    Chennai, India
    Posts
    74
    Points
    708
    Level
    Transformer less power supply is risky one. So can you tell me your requirement (application of the power supply) and specification of the power supply. Then only we can able to suggest the type of power supply to be used. Because you can do it by,
    1. Capacitive
    2. Zener Diode
    3. SMPS
    SMPS provides higher output Efficiency and high current output. Others may not be suitable for high Power application. But you can improve the power rating by cost.
    Replay me with required specification and application, i will give you circuit. I had worked on it!
    •   Alt3rd May 2011, 11:33
      advertising
  8. #8
    Newbie level 1
    Points: 13, Level: 1
    Join Date
    Nov 2014
    Posts
    Points
    13
    Level
    230vac to12vdc converter circuit
