+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Newbie level 1
    Points: 1,527, Level: 8
    Join Date
    Jul 2004
    Posts
    Points
    1,527
    Level
    8
    bmp image read
    hi,
    i need 'c'code to implement bmp image read and perform hough transform on the image.
    •   Alt11th July 2004, 16:47
      advertising
  2. #2
    Member level 4
    Points: 2,054, Level: 10
    Join Date
    Jun 2004
    Posts
    70
    Points
    2,054
    Level
    10
    bmp image read
    I suggest you use matlab. It support bmp reading & managing. Work with matlab is eassier than c.
    •   Alt12th July 2004, 11:15
      advertising
  3. #3
    Full Member level 3
    Points: 3,024, Level: 12
    Join Date
    Jun 2003
    Posts
    161
    Points
    3,024
    Level
    12
    Re: bmp image read
    hi baku_111
    BMP file format is the simplest posible image format (only the simple compression if many points in the given line has exactly the same ray level)
    In general it contains header and body with actuall gray levels (pixel by pixel). The color bmp contains the color map information inside their header.
    I have written several lines of code ( in C ) which reads the BMP files but it is very primitive and was intended for my internal use so I dont recommend them to you.
    But I am pretty sure that in the http://sourceforge.net/ you will find plenty of code on this subject.
    Matlab can read the BMP files directly also.
    Best regards
    dora
    •   Alt13th July 2004, 07:53
      advertising
  4. #4
  5. #5
    Newbie level 6
    Points: 1,572, Level: 9
    Join Date
    Jun 2004
    Posts
    13
    Points
    1,572
    Level
    9
    bmp image read
    i think u need to get header information about the BMP file format .. so . plz do search on the google.com as BMP File Header Information
  6. #6
    Full Member level 6
    Points: 3,715, Level: 14
    Join Date
    Jul 2004
    Cairo, Egypt, Egypt
    Posts
    352
    Points
    3,715
    Level
    14
    Re: bmp image read
    amazing site for you is www.codeproject.com
    •   Alt3rd August 2004, 19:39
      advertising
  7. #7
    Member level 3
    Points: 1,770, Level: 9
    Join Date
    Sep 2004
    Posts
    61
    Points
    1,770
    Level
    9
    bmp image read
    Try using GDI+ library, It has Bitmap class reads directly a bmp image.
