[SOLVED] calculate mutual inductance from two close coil from s parameters
grit_fire
Member level 5
USA
calculate mutual inductance of two close coils from s parameters
Hi, all,
I have two coil inductors placed with one above the other. I managed to obtain the s-parameters s11, s12, s21 and s22 using ADS momentum.
Does anyone know how to calculate the mutual inductance between them using the s-parameters obtained?
Thanks!!
Re: calculate mutual inductance of two close coils from s parameters
First transform the S-parameter to Z-parameter.
Then mutual inductance=imag(Z12)/omega.
Hi, thanks for reply! Now I got it.
Conversion from s parameter to z parameter requires the Zo value, which is the characteristic impedance of transmission line? I am using ADS momentum layout to draw my two inductors. Could you tell me how do I know the Zo value? Or is it just 50ohm no matter what?
Thank you for the help!
The transformation from S-parameter to Z-parameter depends on Z0, you can refer to Tab. 4.2 in Pozar's book -- Microwave engineering.
As for the Z0 used in ADS momentum, it is believed to be 50 ohm which is the default value if you haven't changed that when exporting S-parameter.
Thank you! I really appreciate your help!
