+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 3
    Points: 856, Level: 6
    Join Date
    Sep 2010
    Posts
    29
    Points
    856
    Level
    error in HFSS"Unable to create child process"
    hello every body
    when i run programm in HFSS it gives me error:
    "*Global - Messages
    [warning] Left-alt + shift is currently used by the system to toggle the input language. It is also used in some portions of this application, which may cause the input language to change unexpectedly.
    packagehfss (C:/Program Files/Ansoft/HFSS12/Examples/Projects/packagehfss/)
    packagehfss (DrivenTerminal)
    [error] Unable to create child process: mesh3d, error code = 5
    [error] Simulation completed with execution error on server: Local Machine.
    what should i do
    thanks
    •   Alt19th April 2011, 11:20
      advertising
  2. #2
    Full Member level 6
    Points: 3,285, Level: 13
    Join Date
    Dec 2009
    land of the free
    Posts
    345
    Points
    3,285
    Level
    13
    Re: error in HFSS"Unable to create child process"
    Contact your ANSYS Application Engineer or post here for someone to troubleshoot.
    Have fun
    •   Alt19th April 2011, 14:55
      advertising
  3. #3
    Join Date
    Sep 2010
    Posts
    29
    Points
    856
    Level
    it gives the error for all programms
    •   Alt19th April 2011, 15:06
      advertising
  4. #4
    Advanced Member level 2
    Points: 4,716, Level: 16
    Achievements:
    7 years registered
    Join Date
    Mar 2009
    Posts
    559
    Points
    4,716
    Level
    16
    hi
    this TEE have no problem in simulation i cant understand your problem
    2 members found this post helpful.
  5. #5
    Join Date
    Sep 2010
    Posts
    29
    Points
    856
    Level
    thanks
    i reinstalled the HFSS and the problem has been solved.
