hodahussein
Full Member level 2
deal all
how can pipelining hardware operate at a higher frequency than non pipeline?
if i assume "a*b*C*data" as an example implemented with two case .
first we need to 3 multiplier.
in case non pipeline method if i design this operation in single stage and single process like this
PROCESS(Clk,a,b,c,data)
BEGIN
if(rising_edge(Clk)) then
--multiplication is done in a single stage.
result <= a*b*c*data;
end if;
END PROCESS;
so the result will be 3 multiplier cascaded with them and connect to flip flop
so the result will be available at each clock
in second case pipeline: i divide this operation to 3 stage instead of single stage and i put flip flop after each multiplier stage
so the result will be available after 3 clock .
how can flip flops reduces the delay through the combinatorial logic?
is pipeline faster than non pipeline hardware? why?
wait your help
thanks
BEGIN
end if;
END PROCESS;
wait your help
thanks
