[SOLVED] GSM Modem SIM300 and PIC16F877A accessing problem
speedEC
Full Member level 6
GSM Modem SIM300 and PIC16F877A +AT+CLCC Command problem
I am new to PIC world and also I am moderate on C/C++. I have already communicated GSM Modem (SIMCOM300) using MS VB6.0 from PC successfully. Now I tried to communicate GSM Modem from PIC16F877A. I can able to send and receive sms, ring tone from/to GSM Modem SIM300 and PIC16F877A. All SMS commands works fine. But, when I issue "AT+CLCC" Command, it also works and also the commands followed by are also executed well, but it didn't come out from the loop. I have to switch-off the power and restart. Then only PIC process the command. Can you pl help me to locate the issue and guide me to solve this problem. I will be very humble and thankful to you if anyone provide help to solve this issue.
PIC16F877A
HI-TECH C PRO Compiler (MPLAB v8.63)
SIMCOM300 GSM Modem
LCD JHD 162A
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
#include <stdio.h>
#include <htc.h>
#include "usart.h"
#include "lcd.h"
#include "string.h"
__CONFIG(HS & WDTDIS & UNPROTECT &  LVPDIS);
unsigned char gsmInput[60];
unsigned int i=0;
unsigned int lenOfGSMInput = 0;
bit OK;
bit Error;
bit Ring;
void showGSM_DATA(char GSM_DATA[]){ //to show the GSM OUTPUT after eliminating the chars '\r' and '\n'
    if (strcmp(GSM_DATA, "OK") == 0){
        OK = 1;
    else if (strcmp(GSM_DATA, "ERROR") == 0){
            Error = 1;
    else if (strcmp(GSM_DATA, "RING") == 0){
        Ring = 1;
        GSM_DATA[0] = '\x00';
        puts("AT+CLCC");
        putch(0x0D);
    else{
        lcd_clear();
        lcd_goto(0);
        lcd_puts(GSM_DATA);
} // end function showGSM_DATA
void main(int argc, char* argv[]){
    unsigned char input;
    INTCON=0;   // purpose of disabling the interrupts.
    lcd_init(); // initiate LCD
    init_comms();   // set up the USART - settings defined in usart.h
    puts("ATE0");
    putch(0X0D);
    puts("AT+CMGF=1");
    putch(0X0D);
    while(1){
        input = getch();    // read a response from the GSM
        switch(input){
            case '\x0A': // if line feed detected in the GSM output i.e. '\n'
                        break;
            case '\x0D': // if carriage return detected i.e. '\r'
                        gsmInput[i] = '\x00';
                        lenOfGSMInput = strlen(gsmInput);
                        if (lenOfGSMInput > 0){
                            i = 0;
                            lenOfGSMInput = 0;
                            showGSM_DATA(gsmInput);
                        break;
            case '\x3E': // if greater-sign (in order to send SMS)
                        break;
        default: // if characters received
                gsmInput[i] = input;
                i++;
                break;
        }//end brace for switch
    } //end brace for while loop
}//end brace for main
Try to test these two commands with the hyperterterinal first. See if you get the expected response from the module.
Yes. I already tested with hyperterminal. There is no problem.
Hi seadolphine, Can you pl help me to correct the issue?
Try the following:
1- Comment this part of the code and see if the program flow will continue normally.
        Ring = 1;
        puts("AT+CLCC");
        putch(0x0D);
2- If the program ran normally, then the problem is specifically in the command "AT+CLCC". It may be that the MODEM is still sending some characters, or the MODEM's response is delayed for some reason while you are trying to send it another command.
Hope this helps.
Good Luck
Try the following:
        Ring = 1;
        puts("AT+CLCC");
        putch(0x0D);
Hope this helps.
Good Luck
I have changed the code but the same result. I worked with hyperterminal also. It works fine. No problem there. I think problem in my code. I sent you the entire code for your review. Pl go thro' my code and try to find out the problem. I need your help. Pl.
For your information:
The following code works fine. (I have enabled Clip using AT+CLIP=1 to avoid AT+CLCC command. Before this, If I disconnect the call after processing AT+CLCC response (+CLCC : 1,1, ..), I cannot receive "NO CARRIER" message. Now I receive "NO CARRIER" because of "AT+CLIP" command)
Just display the GSM_DATA (No data validation):
OK = 1;
if (strcmp(NextCmd, "CMGF") == 0){
strcpy(NextCmd, "CLIP");
puts("AT+CMGF=1");
putch(0X0D);
if (strcmp(NextCmd, "CLIP") == 0){
*NextCmd = 0;
puts("AT+CLIP=1");
putch(0X0D);
return;
Error = 1;
*GSM_DATA = 0;
return;
if(strlen(GSM_DATA) > 6){
lcd_clear();
lcd_goto(0);
lcd_puts(GSM_DATA);
*GSM_DATA = 0;
return;
*** The following also works fine but only one time(Startup Commands like ATE0, AT+CMGF=1, AT+CLIP=1) and Any Phone/SMS received (After Successful Startup Commands Execution). If I send another SMS/Phone nothing happen. I have to restat the device. GSM Modem working correctly.
Just I add substring function. Thats all:
substring(0,14,GSM_DATA);
void substring(size_t start, size_t stop, char src[]){
int j = 0;
if (start >= stop){
//return substringOfInput;
return;
for(i = start;i < stop; i++){
substringOfInput[j] = src;
j++;
substringOfInput[j] = '\x00';
lcd_clear();
lcd_goto(0);
lcd_puts(substringOfInput);
*src=0;
*substringOfInput=0;
j=0;
return;
Can you pl help me?
Hi seadolphine,
I found the bug I made in the code inside "substring" function. I already declared "i" as global variable. I removed and also change the code line
int j = 0;
if (start >= stop){
return;
j++;
lcd_clear();
lcd_goto(0);
*src=0;
j=0;
return;
to
for(int i = start;i < stop; i++){
Now everything works fine. Great Thanks.
