ihsanuk
Junior Member level 1
Dear All
How are are you peoples
I working on 8051 based project i require
1- the AC volt coding based ADC 0808 based ICs,
2 Threshold based switching using AC volt meter reading i.e. if voltages is between
160 VAC and 260 VAC the Port 3.0 bit high
if <169Vac and >260Volt Ac than Port 3.0 bit Low.
Thank you in advance
ihsan ullah khan
ihsan ullah khan
