+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Full Member level 4
    Points: 2,684, Level: 12
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Posts
    201
    Points
    2,684
    Level
    12
    AC Analysis of single opamp differential amplifier Pspice simulation
    Im trying to do a ac analysis of a opamp differential amplifier the circuit is shown below.
    The input is fed with a common mode ac signal 1 vpp.
    The differential stage is given a 6V offset too..
    So for the common mode signal the output ideally will be 6V dc signal only.But when i do the AC analysis im getting something like this..
    Can somebody tell me why
  2. #2
    Member level 1
    Points: 501, Level: 4
    Join Date
    Mar 2011
    Australia
    Posts
    40
    Points
    501
    Level
    Re: AC Analysis of single opamp differential amplifier Pspice simulation
    The transient in the waveform is around BW cutoff of the circuit. Can you elaborate more, what exactly are you showing? Is is written there "N differential..?"
    •   Alt28th March 2011, 22:48
      advertising
  3. #3
    Super Moderator
    Points: 239,611, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,611
    Level
    100
    Your circuit measures common mode rejection ratio, as expectable for any real OP, it's below infinity...
    The measurement correspondends almost exactly to the datasheet's CMRR specification of about 60 dB at 1 MHz.
    1 members found this post helpful.
    •   Alt28th March 2011, 23:04
      advertising
  4. #4
    Full Member level 4
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Posts
    201
    Points
    2,684
    Level
    12
    Thats true..but ive a question about the dc point..May be this is due to my ignoance about ac analysis...
    what im asking is that,,,,Isn't the output voltage should rise frm the offsetted 6v dc rather than from 0v dc,after 100kHz?
    For zero differential input i ve offsetted the opamp at 6v dc.
    Thanks For any help
    Regards
    •   Alt29th March 2011, 01:34
      advertising
  5. #5
    Full Member level 4
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Posts
    201
    Points
    2,684
    Level
    12
    or does the ac analysis will kill all the dc sources?? and show only relative values?? or is there some error in my circuit?
  6. #6
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,611
    Level
    100
    For the displayed response, yes. If the DC component would be shown at all (it is e.g. in a fourier transformation), it's written at frequency 0, which is never included in an AC analysis. A reasonable DC operation point inside the linear voltage range is however a required for the AC analysis devices like OPs.
  7. #7
    Junior Member level 2
    Points: 1,326, Level: 8
    Join Date
    Jul 2007
    Posts
    20
    Points
    1,326
    Level
    8
    Your sim results are as expected. AC analysis doesnot kill dc sources, it will take dc points before calculating AC analysis data. You are not offsetting the opamp as you mentioned but giving common mode signal on dc 6V . Are u clear?
  8. #8
    Full Member level 4
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Posts
    201
    Points
    2,684
    Level
    12
    I was thinking that since the zero differential input voltage will provide an output of 6V , i thought the 6v dc will level shift the output of the opamp & thinking that the equation for the output is
    Vo=Vref+Vdiff*G
    Vref=6V
    G=1
    So thats becoz i asked so.
    I think now it is becomming clear..
    Thanks..
    •   Alt29th March 2011, 11:10
      advertising
  9. #9
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,611
    Level
    100
    AC analysis is small signal analysis. It determines the change in output voltage generated by a small (or as the mathematicans say infinitesimal) change in input voltage. So the DC level is always ignored.
