Mikro c pro Timer not working
fateme.m
Newbie level 5
it is my program but unfortunately timer is not unable
without any error
please help me
void interrupt() {
cnt++ ;
PIR1.TMR1IF = 0;
TMR1H = 0x80;
TMR1L = 0x00;
void main() {
ANSEL = 0;
ANSELH = 0;
PORTB = 0xF0;
TRISB = 0;
T1CON = 1;
PIR1.TMR1IF = 0;
TMR1H = 0x80;
TMR1L = 0x00;
PIE1.TMR1IE = 1;
cnt = 0;
INTCON = 0xC0;
do {
if (cnt == 76) {
PORTB = ~PORTB;
cnt = 0;
} while (1);
Thanks
i have PIC16F887
additionally this program correct worked with other compiler(MPLAB)
Did you just modify the code in the MPLAB folder and recompile in MikroC? Or did you build a new project folder from scratch for MikroC?
Also did you disable context-switching?
Check this appnote out:
Interrupts (mC PRO for PIC)
Hope this helps.
The code should work as far as I can see although I have not simulated or tried it in hardware.
Do you have the configuration fuses set correctly? Is the PIC running at all?
Brian.
