Is this Absolute Encoder suitable for my project ?
amit88
Newbie level 2
Will this encoder work with my project?
Hi
I need to use an encoder in my final year project. I need the encoder to record the movement of a voltage control knob. The knob will be rotated clockwise and anti-clockwise several times during its operation. The range of its movement will be limited between 0 - 70 degrees ( I am trying to achieve a resolution of 0.5 degrees, I understand this encoder will only be able to give upto 64'').
Now, I am planning to use the EAW- Absolute Contacting Encoder (ACE)
(Part no: EAW0J-B24-AE0128L), could you please tell me if this encoder will be able to give me the correct position if I first rotate the knob clockwise and then a few degrees anti-clockwise ? Not sure if the absolute encoder has a sense of direction.
Thanks
Amit
P.S Here is the datasheet for the encoder :View attachment ace.pdf
