yumurt
Newbie level 1
Hi everyone;
I want to simulate 1D infinite dipole array. I use master/slave BCs in the direction of periodicity and radiation BC on other faces. I also use a lumped port to excite the antenna.
However, if I simulate the far field results, the antenna pattern does not look like as it's expected. The pattern is not as norrow as I expect.
If I simulate 2,4 or 8 anttennas I can see that the pattern gets narrower. But if I use master/slave it seems, it does not work.
Can anybody help me, what is the problem?
