How to interface LCD to 89s52/89v51 using I2C protocol
shreyas.p
Newbie level 3
I'm doing a project named "Implementation of I2C Protocol"
I'm required to show the working of I2C protocol using a micro controller (say AT89s52) as a master and two slave-devices.
Slave Device #1: LCD
Slave Device #2: Not decided yet
I did some research on the internet and learned that 89s52 doesn't have hardware I2C interface. So either I will have to go for a microcontroller that does support I2C interface or implement bit-banging to implement I2C.
I have never implement bit-banging. So anyone of you have knowledge about it, please share it with me.
I have searched on the internet and found some bit-banging examples. I have attached it alongwith this thread. Please see.
I'm trying to interface LCD via any general purpose I/O expander
eg. PCF8574
As I'll be having more than 1 device on the I2C BUS, I'm confused as to how to address a specific device.
For eg. I want to display "Hello" on LCD (slave device #1), how do I address it and then write the data to it?? :roll:
Also if someone has any suggestions for the second slave device, please comment.
Some info on I2C:
I2C Bus Technical Overview and FAQ - Embedded Systems Academy
Thanks in advance.
  • I2C.doc
1. The document you shared contains code for PIC microcontroller as (TRISB TRISA all happens in PIC).
2. Bit banging is easy, follow rickeys world website on 8051 , so many examples for the same, use keil uvision or RIDE to compile those.
3.To interface LCD over I2C you either need a another MCU as I2C slave or I2C IO expander, another MCU would be cheaper :)
4.While coding the same, just in slave define control registers and data registers. anything you write in data register needed to be displayed on LCD, you may put a looped routine to paste everything on LCD .
5. Or you may simply configure another 8051 MCU as slave IO expander. Depends on choices you have.
happy coding :)
Will the following code work, if I implement it on 89s52?
/* Hardware-Specific Support Functions That MUST Be Customized */
#define I2CSPEED 100
void I2CDELAY(int delay) {volatile int v; int i; for(i=0;i<delay;i++) v;}
unsigned READSCL(void) {return(1);} /* Return current level of SCL line, 0 or 1 */
unsigned READSDA(void) {return(1);} /* Return current level of SDA line, 0 or 1 */
void CLRSCL(void) {}
void CLRSDA(void) {}
void ARBITRATION_LOST(void) {}
/* Global Data */
unsigned start = 0;
void i2c_start_cond(void)
/* if start == 1, do a restart cond */
if (start)
/* set SDA to 1 */
READSDA();
I2CDELAY(I2CSPEED/2);
/* Clock stretching */
while (READSCL() == 0); /* You should add timeout to this loop */
if (READSDA() == 0)
ARBITRATION_LOST();
/* SCL is high, set SDA from 1 to 0 */
CLRSDA();
CLRSCL();
start = 1;
void i2c_stop_cond(void)
/* set SDA to 0 */
CLRSDA();
/* SCL is high, set SDA from 0 to 1 */
if (READSDA() == 0)
ARBITRATION_LOST();
start = 0;
/* Write a bit to I2C bus */
void i2c_write_bit(unsigned bit)
if (bit)
READSDA();
else
CLRSDA();
/* SCL is high, now data is valid */
/* If SDA is high, check that nobody else is driving SDA */
if (bit)
if (READSDA() == 0)
ARBITRATION_LOST();
CLRSCL();
/* Read a bit from I2C bus */
unsigned i2c_read_bit(void)
unsigned bit;
/* Let the slave drive data */
READSDA();
bit = READSDA();
CLRSCL();
return bit;
/* Write a byte to I2C bus. Return 0 if ack by the slave */
unsigned i2c_write_byte(int send_start, int send_stop, unsigned char byte)
unsigned bit;
unsigned nack;
if (send_start)
i2c_start_cond();
for (bit = 0; bit < 8; bit++)
i2c_write_bit(byte & 0x80);
byte <<= 1;
nack = i2c_read_bit();
if (send_stop)
i2c_stop_cond();
return nack;
/* Read a byte from I2C bus */
unsigned char i2c_read_byte(int nak, int send_stop)
unsigned char byte = 0;
unsigned bit;
byte <<= 1;
byte |= i2c_read_bit();
i2c_write_bit(nak);
if (send_stop)
i2c_stop_cond();
return byte;
