+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Full Member level 5
    Points: 4,035, Level: 14
    Achievements:
    Created Blog entry Created Album pictures 7 years registered
    MahmoudHassan's Avatar
    Join Date
    Oct 2010
    Posts
    311
    Points
    4,035
    Level
    14
    Blog Entries
    8
    Configuring port A as digital input for pic16f877a in MikroC
    Hello
    i wanted to configure port A to be digital but i have problem with that simply it
    doesnot worked
    iam using MikroC
    PIC16F877a
    attached protues file for the problem
    i tried to configure it like that
    first iteration
    ADCON1 = 0x0F; // All AtoD pins on PORTA to digital
    CMCON = 0x07; // Disable Comparators
    ADCON1 = 0x0F; // Make PORTA all inputs for switches
    Second iteration
    ADCON1 = 1; // Set inputs as analog, Ref=+5V
    TRISA = 0x00; // Set PORT A as inputs
    Third iteration
    PORTA = 0;
    ADCON1 = 0x06;
    TRISA = 0xCF;
    Fourth Iteration
    ADCON1=6;
    TRISA=1;
    so anybody recommend me other iterations
    Thanks
    (iam newbie)
    any help appreciated
    •   Alt11th March 2011, 04:39
      advertising
  2. #2
    Advanced Member level 3
    Points: 5,999, Level: 18
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
    Re: Configuring port A as digital input for pic16f877a in MikroC
    you can just call the function in mikroC? haha
  3. #3
    Full Member level 5
    Points: 5,121, Level: 16
    Join Date
    Mar 2006
    Posts
    309
    Points
    5,121
    Level
    16
    hi
    in mikroC too you have to configure the ports as inputs and outputs.there's no function in microC which automatically make ports. if you want to make inputs, write 1 to the pins which is to be used as an inputs
    disable ADC and Comparators.it's clearly mentioned in microchip data sheet. i think the system is not working because you did not configure the controller parameters like MCLR in proteus and the compiler.
    ml
    1 members found this post helpful.
  4. #4
    Full Member level 5
    Achievements:
    Join Date
    Oct 2010
    Posts
    311
    Points
    4,035
    Level
    14
    Blog Entries
    8
    I don't know what is MCLR ?
    any information about it ?
    •   Alt11th March 2011, 16:23
      advertising
  5. #5
    Full Member level 5
    Achievements:
    Join Date
    Oct 2010
    Posts
    311
    Points
    4,035
    Level
    14
    Blog Entries
    8
    Thanks a lot finally it works (i don't know how but it did ! )
    But what about MCLR usage ? what is it ?
  6. #6
    Newbie level 1
    Points: 249, Level: 2
    Join Date
    Aug 2011
    Posts
    Points
    249
    Level
    MahmoudHassan
    can you tell me how did it work plz
  7. #7
    Full Member level 5
    Achievements:
    Join Date
    Oct 2010
    Posts
    311
    Points
    4,035
    Level
    14
    Blog Entries
    8
    ADCON1=0b00000110;
    TRISA=255;// configure port A as input
    but take care it is for pic16f877a in MikroC
  8. #8
    Administrator
    Points: 69,113, Level: 64
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,113
    Level
    64
    Blog Entries
    Quote Originally Posted by MahmoudHassan View Post
    The MCLR has two functions:
    1. a MCU reset pin (Master Clear)
    2. Vpp a high voltage (9-13v) for programming the device's Flash and EEPROM
    Many of the PICs allow the MCLR feature to be disable so that the pin can act as a normal I/O pin.
    MCLR Pin function with ICD3
    In-circuit Serial Programming (ICSP)
    Hope the info clears up the question concerning the MCLR.
    BigDog
    •   Alt4th August 2011, 21:20
      advertising
  9. #9
    Newbie level 1
    Points: 133, Level: 1
    Join Date
    Mar 2012
    Posts
    Points
    133
    Level
    in second iteration
    U write :
    if U want port A as input you must config it like that TRISA = 0xff;
    and this what happened with you when you write TRISA = 255; because ff == 255
    this my vision
