CReating Netlist in Orcad Capture
Prince Moses
Bangalore
hi mate... I am using Allegro 16.2 Version PCB editor, where i want to import netlist generated by orcad capture.
While creating netlist, what are the options to be selected in Create netlist window..
Tools--> Create netlist -->> ??????
i want to create netlist for allegro 16.2
thank u so much..
Prince Moses
Following are the steps to create netlist,
Tools--> Create netlist -->select PCB Editor tab-->For further steps find the attached document.
if it asks for over write the created netlist click on ok. If it creates netlist then no problem, if not,again go to create netlist and then pcb editor tab after that besides to create pcb editor netlist, setup option is there click on that button and then check for configuration file whether it is assigned or not, if not then navigate for the configuration file. After that it should work.
Regards,
Hanumagouda patil
  • pcb editor file.doc
hi mate.. i thank u so much for yr reply..... thank u..
yrs...
Prince
Its my pleasure, All the best for ur career in pcb designing..... ve blast.
Yrs,
Hanumagouda
